Sponsored by: Innova
Perfect Stereo Settings
Old Nov 26, 2007 | 04:01 PM
bwyer09's Avatar
bwyer09
I have a stock stereo, stock speakers, two 12" subs, and a 1200 watt amp in my truck. I was wondering what would be the perfect settings for my stereo so I can get the most out of everything? I drive a 2002 Ford F150. Also, if I bought a new stereo, would I be able to get more output? Thanks.
Old Nov 26, 2007 | 06:34 PM
gistecknician's Avatar
gistecknician
There is no such thing as the "perfect" settings on any system! There are many things that come into play:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
1) Type of music you listen to<o></o>
2) Your ability to differentiate tones (you may or may not be "tone deaf")<o></o>
3) Number of people in the vehicle when you dial your system in<o></o>
<o></o>
I could go on, and on....you will just have to sit and try and figure out what's best for you. I have literally spent hours trying to get my stereo set just right, and in the end I am never 100% satisfied. <o></o>
<o></o>
In other words.....Good Luck!<o></o>
Last edited by gistecknician; Nov 26, 2007 at 06:47 PM. Reason: I can't spell "the" when typing fast, always comes out "teh"...go figure
Old Nov 26, 2007 | 11:32 PM
angus's Avatar
angus
The perfect setting would be whatever gives you flat or at least smooth frequency response. The factory sound will probably run out of power and clip before the subs do. It'd be better to have an active crossover so no bass goes to the factory amp and speakers. Then they'd play louder and last longer.
Old Nov 27, 2007 | 02:05 AM
ididntdoit99's Avatar
ididntdoit99
Yeah, wouldn't it be wonderful if it was that easy? If somebody just told you what to set it to and it was done.
Naw, man, you're gonna have to sit down and just mess around until it sounds good to you.
Then when you think it sounds good, try another cd, you'll probably want to change it again.
and again
and again
Like gistecknician said, it'll never be perfect.
Old Nov 27, 2007 | 08:03 AM
chucks_net's Avatar
chucks_net
I used to be an engineer in the entertainment industry -acoustics was always a challenge
Humans are very sensitive when it comes to audio clarity -you will deal with a little visual interference but you will become quickly frustrated with just a little audio interference...
It does depend on the source quality and what you like. From what you describe you like it LOUD -you want a concert in your truck. My suggestion is to swap out your 12' subs for some EV full range concert speakers (they are not all that expensive)
Old Nov 27, 2007 | 04:42 PM
bwyer09's Avatar
bwyer09
Alright then. Chuck was right, I do like it loud. I listen to country and rap, and just want to get the highest possible boom out of my subs. I was just wondering where I should have the bass, fade, etc, etc, etc.
Old Nov 28, 2007 | 11:33 AM
2000silverbullet's Avatar
2000silverbullet
Does your amp power all your speakers or just your subs? I was running a similar setup when I had my factory cd player in my F250. I ran all my speakers off the 1 amp (it's a 6 channel amp). I would put the volume at a "comfortably loud" listening level with the gain all the way down on the amp, then adjust the gain until it's at a level that doesn't clip your speakers...
Like others said, you'll never get it perfect. I have a Pioneer AVIC-N1 in my truck with so many audio settings that it drove me nuts adjusting it for each song or type of music so, as mentioned on the Ron Popeil Rotisserie infomercials, I set it and forget it....
Old Nov 28, 2007 | 06:08 PM
bwyer09's Avatar
bwyer09
Just to my subs. All I want is for my subs to slam louder and harder. Any ideas?
Old Nov 28, 2007 | 06:40 PM
chucks_net's Avatar
chucks_net
Yes go withEV full range concert series subs
Old Nov 28, 2007 | 07:13 PM
fordboy_52's Avatar
fordboy_52
buy new subs then, cause u will never be happy if u try to get the max out of a sub. you never turn an amp up all of the way or else it will distort and sound like crap. i always turn them up 3/4 of the way max.
Matt
Old Nov 29, 2007 | 02:56 PM
bwyer09's Avatar
bwyer09
Forget it. I'll just try to dick with the settings until i can find a good sound. Thanks for trying to help.
Old Nov 29, 2007 | 05:12 PM
CobraXP's Avatar
CobraXP
I'm guessing you are running an inverter to run your amp on RCA's, or you split the signal in the back and have wire inputs on your amp (you didn't specify your amp or subs). You also didn't mention how the power and ground are run on your amp.
First thing I would recommend is changing the head unit to something with more variable controls and sub outputs on the head unit. There are too many to name head units out there that have 3 way control (front, rear, and sub controls), db control, etc. Most will push 25-50 watts per channel on front and rear, so you are good for what you describe you want there. This will give you the extra control for the sub.
We need to know now what amp and subs you are running and what your current wiring and settings on the amp are. Also, what type of box are you running?
Like others have said - there is no magic numbers we can give you to make it perfect. If we have the right info though, we might be able to get you close or help out some...
