the same thing happened to mine so it might be the same problem?
the little drain motro/servo thing (whatever it is) burned out and wouldn't let the water drain. the apartment maintenence guy installed a new one, have no clue how much it cost.
it lasted about 3 weeks and burned out again, so he replaced the whole thing.
but it was not a whirlpool, it was some off brand cheap thing, i would imagine whirlpool having higher quality parts.
the motor thing was located directly under the drain from the washer unit, on mine you could actually unhook it from the actuator and manually drain it, which diagnosed the problem as the actuator motor not working.
It may be going into a garbage disposal and the drain is clogged.. make sure that is clear..
You might also want to try and run the hose into a bucket to see if the pump works on the dishwasher.. That will also tell which side is the problem the drain or the washer.
If you don't have a garbage disposal then it should be easier to determine if it is blocked.
You should be able to hear the pump kick on. If you do, then the screen is most likely clogged. Even if the pump is toast, it's an easy fix that you can do yourself.
Also may want to check and be sure a piece of clear plastic did not make its way into the washer and may be covering the drain. Like a piece of Saran Wrap.
On another thought, if the water does pump out but the washer is leaking during use. My wife was using some type of soap that foamed too much. The foam would leak out the door during use. Changing soap stopped this from happening.
A similar thing happened to mine recently, and I immediately suspected the drain/pump and/or its seal. When checking it out, though, I discovered that the float that controls the water level had become discombobulated (tech term), allowing the water level to rise high enough to leak out of the door. It was a quick & easy fix, and should last another 20years
He said it was leaking water on the floor. When I read it the first few times the line that said "It appears that it's not draining at all from the amount of water in it" I interpreted to mean that the amount of water in it did not affect how much it leaked/drained at any given time.
A little more info changes everything. I agree, check the float. If the float is not able to shut the water flow, it will not go to the next cycle.
Well Frank, Now that you mentioned the next cycle, maybe the timer is mal functioning and it never tells the pump to kick on? Maybe try advancing the timer manually and see if it will pump out.
