Sponsored by: Real Truck
drops to idle while driving down the road
Old Jun 20, 2007 | 08:14 AM
mhs53's Avatar
mhs53
Have a 2002 F250 7.3L that when its cold runs great. Let it warm up and drive down the road and it will run just fine for awhile but then it shuts off and drops to about 600 rpm on the tack and if you let off the accellerator it will jump right back up and take off for awhile till it does it again. I have changed the cps and the tps pedal assembly. There are no codes saved. The water in fuel light and engine light pops on when it does it but the fuel filter is new and checked for water and none present. HELP!
Old Jun 21, 2007 | 08:53 AM
ReAX's Avatar
ReAX
The pedal assy would have been my first guess too. Sence there is a light for them, I would check the output on the sensor for the water seperator and fuel filter. Perhaps some one can give you the ohms for them.
Old Jun 21, 2007 | 09:56 AM
mhs53's Avatar
mhs53
But could that sensor cause the engine to just drop to and idle or shut off?
Old Jun 21, 2007 | 10:07 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is there any other symptoms like unusual noise or smoke?
Old Jun 21, 2007 | 10:15 AM
mhs53's Avatar
mhs53
None. The truck runs great! We got a PCM from Ford this morning and installed about 10 minutes ago. Letting warm up and taking it down the road. It only does it after you have been driving for about 30 minutes or when the engine is warmed up and going down the road. I can run then Wam it just shuts off and drops off almost dying but all your values show good on the scanner. Then if you let off the pedal and repress it goes right back where it was before and continues down the road for a whlie. Then it will do it again.
Old Jun 21, 2007 | 10:22 AM
redford's Avatar
redford
I'm not real familiar with the 2002 PSD. Does the truck have a catalytic converter?
Old Jun 21, 2007 | 10:52 AM
mhs53's Avatar
mhs53
well the PCM fixed it so far. We are keeping our fingers crossed
Old Oct 5, 2007 | 04:39 PM
dapa's Avatar
dapa
wat is the pcm
Old Oct 5, 2007 | 08:38 PM
dsldandually's Avatar
dsldandually
Please let me know how you make out with this on I am havint the exact same problem with mine
thanks
Dan
Old Oct 5, 2007 | 10:38 PM
68rr440's Avatar
68rr440
I have a 2002 and there is a recall on the gas pedal, If you haven;t had it done, that might be your problem.
Old Oct 5, 2007 | 11:06 PM
Cowboy Brett's Avatar
Cowboy Brett
The PCM is the computer module that controls the engine.
Old Oct 6, 2007 | 09:27 AM
dapa's Avatar
dapa
i think the cataylstic converter is clogged
Old Oct 6, 2007 | 09:06 PM
F350-6's Avatar
F350-6
The water in fuel light & SES light give me a different idea. Check for a short or chaffing in your main engine wiring harness. They're prone to rub against the valve cover or a bracket. A short here can cause the same symptoms. I've been there.
Old Oct 9, 2007 | 06:00 PM
dsldandually
well after doing some investigating I traced my problem down to the chip not being in tight. I could tap on the side of the PCM with my finger and make it shut off, pulled PCM and chip reinstalled and I could bang on it with my hand and not get it to die. Reinstalled chip with some more 100 mph tape reak tight and it seems to have fixed my problem......for now I hope "knock on wood"
breeze4820
19
Feb 14, 2017 03:15 PM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
texx101
General Automotive Discussion
Aug 15, 2007 12:57 PM
macwilj
Jul 28, 2007 08:26 PM
hsfbfan
Jun 24, 2007 04:33 PM
