software question-user accounts comes up as notepad?
Old Nov 29, 2005 | 06:26 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Question software question-user accounts comes up as notepad?
I think my computer has been altered by a virus maybe. When I try to access my user accounts, a blank notepad file comes up. I have tried to access user accounts in different ways, but the result is the same.
I would restore my OS (XP) but we lost the recovery disk in a house fire. Any suggestions?
Thanks
Old Nov 29, 2005 | 06:33 PM
preppypyro's Avatar
preppypyro
Have you tried running a virus scanner of some sort?
Old Nov 29, 2005 | 07:11 PM
TN-W124 Diesel's Avatar
TN-W124 Diesel
you can restore the xp under: all programs>accessories>system tools> restore
Old Nov 29, 2005 | 09:15 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
I have run some anti-virus programs and they did help. Trend seemed to be the most effective. I believe the virus is gone now, but some changes still remain. I have also ran Norton, Ad-Aware, and Spybot.
I did find the initial restore point that TN-W124 mentioned. Man that is going to take alot of work to backup all my data. I sure would like to fix just this one problem if possible. Thanks for the replies.
Old Nov 30, 2005 | 04:30 AM
Crash687's Avatar
Crash687
try contacting the manufacturer of the computer (Dell, Gateway) . if your computer is of the homebuilt nature, if you have the original product key for XP(should be a sticker on the computer), see if you can borrow a friends copy of XP
Old Nov 30, 2005 | 07:51 AM
TN-W124 Diesel
the restore is reversible, so if you don't like it it can go back to where you were, you should not lose any data, pictures, etc.
Old Nov 30, 2005 | 08:32 AM
Steve_250's Avatar
Steve_250
Use the restore that TN mentioned and go back to a date before the problem started, like a week or so. If that doesn't work, sign in as administrator, co to the control panel and put the users back on.
What about all your data files, such as your mail, bookmarks, etc, are they on the drive?
Do you use outlook? Do a search for outlook.pst and enable the search to look for hidden files. For IE, go to docs & settings, your name, apps, MS, IE, and look in there.
Old Nov 30, 2005 | 08:41 AM
mistakenID's Avatar
mistakenID
Generally the problem with using the restore option is that virii infect that location also so that you get reinfected after removing the original virus.
You can try running sfc /scannow from the command line to check your system files.
ford2go
Dec 2, 2011 07:48 AM
bf250
21
Mar 6, 2007 07:08 AM
Monsta
33
Jul 14, 2004 11:11 PM
theologian
Feb 12, 2004 02:58 AM
drdave
Dec 18, 2003 02:13 PM
