Headliner Material
Old Nov 22, 2007 | 09:04 PM
biggut's Avatar
biggut
Question Headliner Material
Anyone know a source for 1/16" tempered hardboard to make new pieces for the headliner on a 66? 1/8" is fairly easy to find, but any thinner seems impossible. Thanks, Brett
Old Nov 23, 2007 | 07:27 AM
jowilker's Avatar
jowilker
Brett, Why do you need thinner? You have to wet and mold the material to get it to fit. You may have to tie it up on a paint can to dry to get it to fit right.
John
Old Nov 24, 2007 | 09:56 PM
biggut's Avatar
biggut
THE MATERIAL IN MY 66 IS 1/16. dO YOU REALLY THINK THICKER WILL WORK? I GUESS IF YOU HAVE TO WET AND MOLD IT, THICKER WOULD WORK JUST AS WELL! I'M GOING TO GET RIGHT ON IT! THANKS, BRETT
Old Nov 25, 2007 | 04:55 AM
jowilker's Avatar
jowilker
Brett, I don't see why the thicker wouldn't work. I have given some thought to using some staves in the top for more room to add insulation. The cab corners are going to be a pain either way and you may have to make multiable attempts before you get them right. I'm not vertically challenged so the room up there is not an issue for me.
I want to cover mine with a fabric headliner to reduce noise. I have seen some really nice ones installed at car & truck shows.
good luck
John
Old Nov 25, 2007 | 06:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Standard Cabs have a non perforated headliner. The Custom Cabs headliner is perforated. As original, the headliner is 1/8" thick.
Dennis Carpenter sells one or the other, I forget which.
You will also need the 5 U shaped clips (C4TZ-8152140-A) to hold the rear section of the headliner to the front section.
FTE sponsor GREEN SALES has 10 NOS clips in stock = 800-543-4959.
Old Nov 25, 2007 | 07:05 AM
jowilker's Avatar
jowilker
Bill, I have heard some less than kind comments about DCs headliner, concerning both color and fit, but it is the only one available.
John
Old Nov 25, 2007 | 02:50 PM
gustav129's Avatar
gustav129
LMC Truck has grey headliners for the trucks.
Old Nov 25, 2007 | 06:09 PM
jowilker's Avatar
jowilker
Made by Dennis Carpenter
John
Old Nov 25, 2007 | 06:25 PM
gustav129's Avatar
gustav129
Ok, didn't know.
Old Nov 25, 2007 | 06:44 PM
bliss1's Avatar
bliss1
try sacramento vintage ford, for the most part concentrate on ford trucks www.vintage-ford.com, call and they will send a cataloge.
Old Nov 25, 2007 | 07:30 PM
gustav129's Avatar
gustav129
Wow, thanks for the tip Bliss. So far, the only thing I had was the LMC. I'll have to get a catalog from them.
hank89
Aug 4, 2010 04:17 PM
Brett1989
Mar 19, 2008 05:27 PM
catfish101
Jan 1, 2007 10:40 AM
brett_d
32
Sep 10, 2003 09:04 AM
