switchable fuse block?
Old Nov 24, 2007 | 09:22 PM
denman81's Avatar
denman81
Red face switchable fuse block?
alright, need some help. Im adding lights to my truck, LOTS of lights. My idea is i fabricated upfitter switches into my 03 and Id like to figure a way to add a couple more driving lights, clearance lights, ground running lights, ect onto an additional fuse block under the hood with just one of my upfitter switches to turn on the fuse block. What im trying to figure out is there some way for a low amp switch to kick on a whole fuse block? If so can anyone point me in the right direction to pick that part up and the cost? Any other hints or ideas would be appreciated.
Thanks!
Chris
Old Nov 25, 2007 | 07:36 AM
ri_truck_guy's Avatar
ri_truck_guy
Use a relay...low switch voltage causes the relay to close...high power runs through the closed connection.
Old Nov 25, 2007 | 10:55 AM
denman81's Avatar
denman81
so are all relay switches rated the same? Is there such a thing as too much load for a relay switch? If im thinking correctly I can run my main power from my battery through a relay and hook the other end to a fuse box with all my lights running into the fuse box and run the switch to the relay so the whole fuse box has no power untill I turn on the switch to the relay right?
Old Nov 25, 2007 | 11:19 AM
lsrx101's Avatar
lsrx101
You're real close. Most common (ice cube type) relays are 20 or30 amps. Add up the load for the devices that you want to control with it. If you're close to 30, you may want to use a larger relay for some cushion . A plow relay or something similar might be a good choice. If you are drawing a lot of amperage, make sure the line feeding the fuse panel is heavy enough for the load and don't use crimp terminals.
Old Nov 25, 2007 | 12:26 PM
Franklin2's Avatar
Franklin2
He's correct, most of the standard Bosch type foglamp relays are around 30 amps. If you run over 30 amps, just use two relays. One relay can feed one half of the fuse box, and the other can feed the rest. You can also divide it up in thirds and run three relays. The reason you might want to do it this way is the 30 amp relay and the 10 gauge wire needed to supply it are very common and easy to get. You can just run 1, 2, or 3 10 guage wires from the battery to a 30 amp circuit breaker or fuse for each(keep these as close to the battery as possible), and then run to the relays and then the fuse box or boxes.
If you want to figure out the load of any large lighting, take the watts number and divide it by 12 volts, and that will give you the amps the light takes.
If you are going to add a lot of running lights, you might want to add a relay just for them, and instead of triggering the relay with a upfitter switch, you could let the brown running light circuit trigger the relay. Then the extra lights would come on with the rest of the lights automatically.
Old Nov 25, 2007 | 09:10 PM
blue beast's Avatar
blue beast
http://www.skycraftsurplus.com/index...TS&Category=95
The one on the bottom left 300 amps should be plenty!! They also have 80 amp
bosch type relays in the automotive section. IF you are running alot of lights on
the stock switch already I would wire in a relay for that instead of relying on the
switch. Skycraft has some good deals on the marine grade wire that will outlast
the truck if you are planning on keeping it I would only use that.
Old Nov 26, 2007 | 09:02 AM
denman81's Avatar
denman81
Awsome! Thanks alot guys!
Old Nov 26, 2007 | 10:35 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
I buy these by the 10 pak - something like 3-4 bucks apiece with socket.
http://cgi.ebay.com/ebaymotors/Tyco-...spagenameZWDVW
Old Nov 26, 2007 | 09:19 PM
Franklin2's Avatar
Franklin2
Just remember, you have to follow through with the expected load through the whole circuit. A big relay would be fine, and you would not need to use the whole rating. But lets say you are going to use the 80 amp relay, and your loads will be about 40amps. Then you need to use a fuse at the battery around 50 amps in size, run wire capable of carrying 50 amps from the battery to the fuse, and then to the fuse box, and the fuse box needs to be capable of handling 50 amps worth of loads connected to it. Once you hit the fuse box, then you can spread out, and lets say you have a 30 amp fuse in there. Then that circuit should be run with a 10 guage wire.
Fordboy880
Jun 22, 2018 05:01 PM
sgrol
6.7L Power Stroke Diesel
Nov 2, 2014 06:37 PM
E077528
Oct 25, 2014 04:00 PM
11superduty
69
Jul 19, 2014 10:01 PM
wsps1990
Nov 30, 2010 01:36 AM
