92 E-350 Diesel E40D Problem Tranny
Old Nov 24, 2007 | 02:03 PM
HAB's Avatar
HAB
Have a 92 E-350 Diesel E4OD transmission problem.
Today the tranny will work great all day, but tomorrow will kick into limp home mode (shifter light flashing) every time you start up the engine or within a couple of minutes.
Replced the Tranny same problem.
The same symptoms showed up when the wiring harness coming up through the drivers side b-post was nicked a couple of years ago. It was repaired and all was fine, have checked it and it tests ok (continuity through the wire). No new apparent damage to anything visible.
Transmission shop read code indicates bad shift position sensor. Replaced it twice same thing.
Any suggestions?
Old Nov 25, 2007 | 08:47 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have a wiring probem to the shift position sensor. The code doesn't mean the sensor is bad, it means something is wrong with the signal from the sensor. that could be the sensor, the wiring, or sometimes the PCM, but that's very rare. Somewhere you have a damaged wire or a corroded pin.
Old Nov 25, 2007 | 11:18 AM
HAB's Avatar
HAB
Thanks,
That is what I've come to conclude also, but have been unable to locate. Any suggestions as to how to locate precisely?
Old Nov 25, 2007 | 11:56 AM
Mark Kovalsky
You need to follow each wire back from the TRS to the PCM and find the problem. The alternate method is to just replace the wires.
Pokendeye
Apr 17, 2008 01:51 PM
rcraig
Jan 3, 2007 12:54 AM
HAB
Sep 15, 2006 11:24 AM
Volksrod
15
Apr 24, 2006 10:49 PM
dieselcanuck
Nov 12, 2004 01:17 PM
