Bumpside Padded Dash??
Old Nov 24, 2007 | 12:38 PM
68horses's Avatar
68horses
Hey All,
I hope everyone is recovered from bein' Turkey Stuffed! The question is, did any year and/or model of the bumpside trucks com without the padded dash cover? I removed my tortured one and found a nicely painted dash underneath and would like to leave it this way, understanding that I need to cover the mounting slots and holes. What I need to know is what to do for the defroster covers/vents/grates and if some year or model without the pad might have them. If anyone can answer this or even might have a pair of them that they would be willing to sell me it would be greatly appreciated. Click links below for pics:
Thanx In Advance,
Gene
P.S. I could sure use a steering wheel or at least a horn button!!
Old Nov 24, 2007 | 08:13 PM
Redcat Diesel's Avatar
Redcat Diesel
I've never seen a pickup without a dash pad however some of the medium duty ( F500 and up) were built without them.Also the bump side dash was used in 73-79 medium dutys.
Old Nov 24, 2007 | 10:01 PM
marks69's Avatar
marks69
i've got a couple of horn buttons around here. i bought them from ebay but then went with a new wheel and column. i'll look around and post a pic this weekend.
mark
Old Nov 25, 2007 | 12:42 AM
mrcman58's Avatar
mrcman58
Exclamation vent covers
Hi 68 Horses,
as for some defroster covers for the 2 holes! when you took your old dash board out - do you still have it? if so where your 2 vents are molded in to the dash carefully remove them and they will be a perfect fit, razor blade them and peel the foam material away, i had found this out by accident quite a few years back. when this body style pickup & truck was built in south america they didnt all have padded dashes, but if you threw your dash away i have some i have saved from dashes i had trashed in the past, hope this helps, Jess
Old Nov 25, 2007 | 03:42 AM
68horses's Avatar
68horses
Jess (mrcman58),
Yeah, I figured I might be able to use the ones out of the pad, but wanted to keep the pad intact in case some day when H-E-double hockey sticks freezes over I may find someone to re-mold/repair it. I am an over the road truck driver and regularly drive up and down Interstate-5 near Los Banos, just came through there today, in fact. If you were to PM me with your phone number, perhaps I could call you and arrange a time and spot that we could meet up and I could give you a few $$ for the ones you have. Otherwise, I live in Las Vegas and shipping/mail shouldn't be too bad. Let me know and thanks for the thoughts and the reply.
Thanks for all the replies,
Gene
Old Nov 25, 2007 | 04:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Regular Cabs used a horn button. The same one was used 1964/69.
Custom Cabs used a horn ring. The same one was used 1964/69, and is the same as 1963 Falcon.
The steering wheel has been reproduced by Dennis Carpenter in black only. Fits 1964/69 and again it's the same as 1963 Falcon.
The defroster ducts used covers: C7TZ-8104498-A. Fits: 1967/72 F100's thru F750's.
There's no radio grille, the padded dash was perforated for the speaker.
All these trucks came with padded dashes. The dash you removed would have had the defroster covers on it at one time.
All 1967/72 F100/750's have painted dash boards under the pad, as do 1965/66's, and 1973's and up.
JUST DASHES located in the San Fernando Valley, CA can make your old tired padded dash look new again.
Be prepared, the cost is astronomical.
They quoted me $700.00 to repair the padded dash of a 1968 Galaxie XL.
I used an aftermarket plastic dashcap instead. The dashcap glues to the padded dash and costs $100.00.
I don't know if anyone makes the cap for Ford trucks. Ask your local upholstery shop, they might know of a supplier.
Old Nov 25, 2007 | 08:25 AM
fastmover's Avatar
fastmover
You can find replacement dash pads for around $400 in Blue Oval, Dennis Carpenter, MACS and NPD as well as others that are not FTE sponsors. They also have the dash caps that Bill recommended for $80-$100.
Old Nov 25, 2007 | 09:20 AM
freejay's Avatar
freejay
Are those covers for the original pad any good? Anyone using one?
Old Nov 28, 2007 | 08:32 AM
TigerDan's Avatar
TigerDan
Don't give up on the wrecking yards either...I got a perfect dash pad from a '67 for 30 bucks. You might just lucky and find a good one like I did, though most of the ones I came across were pretty bad...
Old Nov 28, 2007 | 05:33 PM
idealtrucks's Avatar
idealtrucks
Yeah, the junkyards are good places to find one. I've found two flawless ones for my two trucks for about $25.
JacoFordCummins
Engine Swaps
45
Nov 4, 2020 09:09 AM
SuperHatch
58
Jun 13, 2019 08:19 AM
LaxPlaya21
Apr 21, 2015 08:17 PM
FortyNiner
21
Oct 4, 2013 07:05 AM
FordManMT
Aug 26, 2013 03:46 PM
