Duraspark coil
Old Jan 25, 2002 | 01:13 PM
captntim's Avatar
captntim
Duraspark coil
Old Feb 4, 2002 | 12:16 PM
parr4's Avatar
parr4
Duraspark coil
'81 F100 w/300L6...stock ignition. What is the output voltage of a stock DuraSparkII coil? I believe my coil output is getting weak and would like to try a better coil. Any suggestions about a 'better than stock' coil? This truck is just a daily driver, so I don't need any 'go fast' parts. Thanks, I appreciate all info.
Dave
Old Feb 4, 2002 | 02:42 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Duraspark coil
Dave, the DuraSpark is around 30-35K volts. The only way that I know of to check it is to ground a sparkplug on the block, and look for a strong "blue" spark from it.
This compares to about 20-25Kv for the ordinary points-type coils. A good aftermarket coil will put out 40-50Kv. The Mallory Promaster is a good bolt-on coil, with no other mods.
Old Feb 5, 2002 | 07:29 AM
chip58's Avatar
chip58
Duraspark coil
I'm real happy with my MSD.
Old Feb 5, 2002 | 08:47 AM
dsc's Avatar
dsc
Duraspark coil
I also have a 4.9L. I am very happy with my MSD 6a and MSD Coil. Art
Old Apr 25, 2024 | 08:52 AM
Dana 411's Avatar
Dana 411
4th Gear
Horseshoe style connect with MSD Blaster?
Can you use the Horseshoe style connector on MSD Coil or any coils w/o the 2 Round post ends opposed to the thread and nut ends?
Old May 3, 2024 | 12:36 PM
AbandonedBronco's Avatar
AbandonedBronco
The horseshoe style connector is a quick connect setup made specifically for the round post ends.
If you want to use another coil, you'll more than likely just have to cut the wires and splice on open end connectors for the thread and nut ends.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
