i6 cylinder head
Old Nov 13, 2007 | 11:14 PM
micman7's Avatar
micman7
i6 cylinder head
Anybody know if the i6 cylinder head is the same on the EFI and carb version of the engine.
Old Nov 13, 2007 | 11:30 PM
hoxiii's Avatar
hoxiii
yes and no.
they will physically interchange, but the EFI head has a smaller, fast burn style chamber. the style of rocker arms also varies between years. EFI are all bolt down style, while carb heads have 3 different arm styles depending on years.
Swapping heads will change the compression ratio by about 1 full point, but will also chage what timing curve the motor wants. The EFI head makes better power at less total advance.
Justin
Old Nov 14, 2007 | 09:49 AM
wildjon300ci's Avatar
wildjon300ci
I found out the hard way, unrecurved DuraSpark-II + EFI head leads to
If you're gonna do it, make sure to redo that ignition curve.
Old Nov 14, 2007 | 12:08 PM
hoxiii's Avatar
hoxiii
Ouch. When'd you do that?
Justin
Old Nov 14, 2007 | 09:31 PM
wildjon300ci
Back somewhere October-November 2004. I drove it around 200 miles home like that. Cruised at 70 the whole way. LOL
It still started and ran, with a little effort before I yanked in and threw a 351 at the truck.
jonathanpatr
Sep 20, 2013 06:47 PM
beanhead6D5
Feb 26, 2012 06:25 PM
My98FordF150
Modular V8 (4.6L, 5.4L)
15
Apr 20, 2007 05:26 AM
