Rebuilt Heads
Old Dec 1, 2007 | 12:24 AM
302 F-150's Avatar
302 F-150
Rebuilt Heads
I am looking for a set of rebuilt heads for the carbureted 302 in my 89 f150. Is there a certain casting number that I should be looking for that is better than others or will any 302 heads work?
Thanks
Old Dec 1, 2007 | 07:43 AM
baddad457's Avatar
baddad457
Steer clear of these two casting numbers: E6SE, D8OE. Both have larger chambers than your present heads. You should have E7TE's now, which are pretty good heads after you port the exhaust sides and remove the Thermactor bumps inside the port.
