starting problem, please help
Old Nov 23, 2007 | 09:05 PM
crobmorris's Avatar
crobmorris
Unhappy starting problem, please help
sometimes it starts fine and some times it sounds like my battery is going dead, {not the battery}. engine is definitly turning, what could it be
Old Nov 23, 2007 | 09:11 PM
khadma's Avatar
khadma
Carpenter Local 745
Why do you say it is not the battery? Is the alternator charging the battery?
Any other conditions?
Old Nov 23, 2007 | 09:15 PM
crobmorris's Avatar
crobmorris
battery meter is reading high and it is a new alternater. it allmost seems like a bad electrical connection.
Old Nov 23, 2007 | 09:21 PM
DJdemon6696's Avatar
DJdemon6696
If it does it when the engine is hot
its normal..
hotter temperture higher resistans in the wire ( ohms ) its normal
( im learning this in my class at school lol )
but if you want to be shure.. just clean the grounds... from battery to chassis chassis to engine block etc etc..
Old Nov 23, 2007 | 09:28 PM
crobmorris's Avatar
crobmorris
today was the first time it would'nt start at all , than 5 min later
it started like it was fine, no problems since
Old Nov 23, 2007 | 09:45 PM
DJdemon6696
when it was hot? or normal temp? or cold?
if it does it again.. start by cheking the ground wires like i said in the first post
Old Nov 23, 2007 | 09:49 PM
khadma's Avatar
khadma
Carpenter Local 745
I agree, see if it does it again and check all the wires associated with the battery starter alt you could have a loose ground and /or bad battery connections. I hope your new alt is up to spec. New parts can go bad too.
Old Nov 23, 2007 | 10:37 PM
crobmorris's Avatar
crobmorris
thanks guys
