Fuel tank..........
Old Nov 23, 2007 | 08:41 AM
jorgholio's Avatar
jorgholio
Fuel tank..........
Yep, me again. I've taken my fuel tank to the rad shop and they soaked it over night. Flushed rinsed, painted, however I still see some smegma(rust) inside. Has anyone heard of a coating you can put in or any ideas. This tank is in awesome shape on the outside but 9 year old gas does wonders. My shop still smells bad.
Old Nov 23, 2007 | 09:08 AM
rockher_man's Avatar
rockher_man
Talking
Have a budddy that used this once...
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
...said it worked.
I have a coupla other buddies that ALWAYS seal motorcycle tanks wheather
building new or rebuilding.
I have no experience with these products...
Good luck...
Old Nov 23, 2007 | 10:20 AM
imlowr2's Avatar
imlowr2
Check with these guys, $34 for a gallon.
http://steeltechsolutions.com/
ask for Dave!
Old Nov 23, 2007 | 10:26 AM
merten's Avatar
merten
jorgholio,
Just a word of caution, before you use that word that starts with an s to describe rust, you should look up its meaning and then pick another word instead.
Old Nov 23, 2007 | 11:21 AM
merc546's Avatar
merc546
Merten. Just looked the word up. I think I like rust better
Old Nov 23, 2007 | 11:34 AM
RUSTY50F1's Avatar
RUSTY50F1
"ME TOO"
Old Nov 23, 2007 | 12:37 PM
fergusonicford's Avatar
fergusonicford
In past years when I have a gas tank that has some internal rust; I remove the sender, throw in about 20 : 3/8" nuts, a gallon of kerosine, and start moving the tank all around so that the nuts roll around and remove any loose scale. Remove 20 nuts and old kerosine, rinse, and seal. I have no idea if this is recommended ....has anyone else ever do this?
Old Nov 23, 2007 | 12:41 PM
49fordpickumup's Avatar
49fordpickumup
fuel tank
POR-15 people have a tank sealer that works. Have a great day,chuck
Old Nov 23, 2007 | 12:46 PM
dennisb56's Avatar
dennisb56
I've used the POR-15 stuff with great results. its held up now for 7 years no leaks, knock wood. This was in a Triumph Stag not a Ford Truck.
Old Nov 23, 2007 | 01:50 PM
CIAF's Avatar
CIAF
Ferguson, we have done that for many years with great results, but found it easier to use a tow chain rather than nuts/bolts. You leave the end of chain out of the tank neck and pull out when finished.
Jon
Jorg, I keep hearing the the POR is a very good product with today's new fuel blends. I helped a guy coat a tank, but itis only a year so far. No problems that I have heard.
Jon
