Engine Block Heater
Old Nov 23, 2007 | 07:08 PM
Ed in Maine's Avatar
Ed in Maine
Yes, it gets the block VERY warm. You can hear the fluid right around the connection when everything is working good. It does draw about 1100W I believe. I put mine on a timer so it comes on about 3 hrs before I leave the house. No need to leave it plugged in all night unless power is cheap, you will notice it on your elec bill though!
Old Nov 24, 2007 | 10:44 AM
OUTPLAYN's Avatar
OUTPLAYN
Can you replace just the cord?
Old Nov 24, 2007 | 11:02 AM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Never have used my block heater...Guess it still works...should work.
No need for it down here in the south. Not yet anyway. Mine is still tucked away.
Old Nov 24, 2007 | 06:30 PM
mxracer3276's Avatar
mxracer3276
From what i was told by others you can replace just the cord, but i was told that it is a dealership part so i dont know if it will be cheap...
Old Nov 24, 2007 | 06:34 PM
ron's power stroke's Avatar
ron's power stroke
for the guy's in need of a block heater.
http://cgi.ebay.com/ebaymotors/OEM-ford-power-stroke-7-3-block-heater-kit-99-2003_W0QQitemZ170172894695QQihZ007QQcategoryZ33613 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Old Nov 24, 2007 | 06:44 PM
mxracer3276
There ya go, thats a solution to...
Old Nov 25, 2007 | 08:59 AM
Cold Man's Avatar
Cold Man
How warm it keeps the engine will depend on the outside temperature and the wind chill factor. Here the temperatures can drop to -40 or -50 and add the wind chill factor to that it can go down to -70 or -80. Those mornings, even with a block heater, the truck dont want to start. I will use both the block heater and a 600w magnetic oil pan heater and still then the tuck starts but it dont like it. something else you can consider is an espar heater system www.espar.com with this system i can leave me truck for a couple weeks and come back and find NO snow on my truck! it works great! thats what i use now.
Old Nov 25, 2007 | 11:45 AM
Fat Diesel's Avatar
Fat Diesel
Cover your bowl of corn flakes boys, 'cause here's my yearly warning about block heaters. Use them if you MUST, but they can and do catch fire sometimes...
Read all about it.
http://www.croberts.com/blockheater.htm
Old Nov 25, 2007 | 01:03 PM
Lead Head's Avatar
Lead Head
The block heater itself does not catch fire, its from damage done to the cord by the operator that causes to catch fire. As long as your not routing the cord through every sharp point in your truck, and then backing up with it stil plugged in..
Old Nov 25, 2007 | 05:02 PM
JAMSRF250's Avatar
JAMSRF250
How long can you leave the block heater plugged in?
Old Nov 25, 2007 | 05:12 PM
kawika's Avatar
kawika
How much spare money do you have. It will hit you in the walet if you leave it on 7x24. I found that out on the next bill. That is why I got a timer.
Dave.
Old Nov 25, 2007 | 05:21 PM
kawika's Avatar
kawika
I had my plug melt and Ford replaced it under waranty. I believe it was due to the salt build-up and corrotion of the plug, and my special way of unhooking the extension cord (forget to unplug and run down the road with a 25 foot extention cord dragging... I was wondering where that cord went (and found it down the road later).
I now take a 3M pad to clean the prongs every month or so.
Dave.
Old Nov 25, 2007 | 05:24 PM
  #28
Lead Head's Avatar
Lead Head
I think they have auto eject plugs for block heaters, that when you switch on the ignition, they automatically force the cord out. They are kind of expensive though, would be nice if ford offered it for a factory option tho.
Old Nov 27, 2007 | 07:44 AM
  #29
02GrayPowerStroke's Avatar
02GrayPowerStroke
Dave.
Now thats funny, Thanks!!
Old Jan 20, 2008 | 08:23 PM
  #30
idylmoments's Avatar
idylmoments
I've had my 2002 PSD for a year and a half and was sure that I read that the block heater was an option and only was installed on trucks in the far north. Thanks to you guys a just ran out and traced the wire and sure enough the plug was tied up right behind the tow hook. How embarrassing. It wouldn't start this morning in below zero wind chill and it's not supposed to get any warmer the next three days so what a relief! There were two days last winter it wouldn't start either.
The g/f thinks I'm nuts as her and the kids are already in bed and I'm out rolling around in the driveway.
