Lock out melted !!
Old Nov 22, 2007 | 11:16 PM
95COLUMBUSF-250's Avatar
95COLUMBUSF-250
Lock out melted !!
I noticed a burning plastic smell the other day and discovered that my plastic lockout **** had melted.When i arrived at home i jacked up the truck and everything seemed fine with the wheele bearing and the brakes.I cannot figure out what made the lockout that hot! Since then i have driven the truck about 200 miles with no problems at all.The only thing i can figure is that mabey i had the brake pistons stick and it all heated up?Im going to replace the stock lockouts with an aftermarket pair (warn) I was wondering if anyone else has had this problem?
Old Nov 23, 2007 | 01:55 AM
Skandocious's Avatar
Skandocious
My first guess would be a bad/un-lubricated wheel bearing. If you're brakes were rubbing enough to melt your hub lockouts, then you would have noticed it driving, not to mention your front rotors should be pretty well glazed over and pads almost non-existent . When you replace your hubs make sure to repack your wheel bearings.
Old Nov 23, 2007 | 07:01 AM
Toyman's Avatar
Toyman
I would suggest that you tear into the front and repack the bearings, don't forget the spindle bearings, while you're in there maybe replace the axle U joints also. While you are putting it back together put a good graphite lube on the caliper slides.
Toyman
Old Nov 23, 2007 | 07:07 AM
phoneman91's Avatar
phoneman91
I usually make a point of feeling the hubs with my hand after the truck has been on a long high speed drive. I do the same with the rear drums. If one of them are warmer than usual--I would check and see what is going on.
Did you check the temperature of your hubs after getting out of the truck?? Are they warm at all??
Brad Brown
Modular V8 (4.6L, 5.4L)
Jan 4, 2017 11:55 AM
Gerryharding12
Jul 25, 2016 06:32 PM
Bootlegger's Deluxe
Jan 12, 2016 04:05 PM
bigguyinmo
Dec 15, 2015 09:46 PM
superstroked6.0
Dec 2, 2015 03:09 AM
