snow driving
Old Nov 22, 2007 | 10:03 PM
laivindil's Avatar
laivindil
snow driving
I've got myself a '96 4x4 V6 auto Explorer and a question.
My transmission (stock) gear selector goes: P R N D 2 1
I've got some pretty gnarly hills where I live and when going down them in icy conditions would it be possible to select 2 or 1 and let off the brake? Would the transmission act like a manny and keep the speed down without needing to brake (and risk skidding)? Or would the tranny automatically select a higher gear once it got up to an appropriate speed?
Old Nov 23, 2007 | 06:40 AM
marragtop's Avatar
marragtop
The trans will stay in whatever gear (1 or 2) that you select. Of course then your engine RPMs will be higher.
Old Nov 23, 2007 | 11:43 AM
99f350sd's Avatar
99f350sd
If you have abs brakes use em if not lower gear and 4wd locked. Be carefull if the tires slip while in 4wd 1st gear you will need to quickly shift up to free the wheeks or else you will be in trouble.
Dick
Old Nov 23, 2007 | 12:19 PM
Bdox's Avatar
Bdox
Or tap on the gas to catch the engine rpm up to the vehicle speed.
Old Nov 24, 2007 | 12:01 PM
mediaman67's Avatar
mediaman67
same truck as I, and we are in snowy weather too - 96's all had ABS as far as I know - my sport does, and it does work really well...
one thing - I would avoid 4Low altogether unless you are stuck or off road and it's not dry, etc... 4H is the best for snowy weather 9 out of 10 times - plus you can't use 4L anyways when you are moving, only from a stand still can you shift everything into 4wd lock - I'm sure you knew that already, but I think people fear the snow on regular roadways, and think you need to use 4L - that's tough on the drive train, but it does work well when you use it in the mud, or off road, etc esp if you are really stuck, etc...
unless you are towing stuff, or have a load, even a a fairly steep grade, 2nd gear is all you would need with the abs - I've never used 1st alone... these trucks in this year are just not that heavy to warrant that really - unless you are talking about an icy 40 degree slope or something... 2nd gears them down nicely for most any slippery hill...
I will tend to use the OD off switch more than anything else in snowy weather, but that is more on the 40mph roadways, and right where the shift point is for OD - (same as downshifting into 3rd...)
Furian
Jun 7, 2018 06:30 AM
U235Fishin'
6.7L Power Stroke Diesel
Nov 17, 2013 09:59 AM
portsample
28
Sep 26, 2013 10:40 AM
Dorman
Jun 20, 2010 04:04 PM
tjay460
Apr 26, 2005 09:39 PM
