Sponsored by: Kumho
violent shake
Old Nov 22, 2007 | 08:27 PM
johnathon's Avatar
johnathon
violent shake
Hi I am new here , lurking for a long time great site , I have a 1982 e350 that drives fine but once in a while if you hit a bump just right the front end shakes violently. When this happens I have to almost come to a stop, when I was a teenager I test drove a truck that did the same thing and I passed on it but never knew what caused it. Getting pointed in the right direction would be a grat help thanks
Old Nov 25, 2007 | 11:16 AM
blue beast's Avatar
blue beast
Vans carry a lot of weight on the front end and they wear out alot of front end components. Jack it up and have your strongest friend shake the wheels in the
12 to 6 oclock plane then in the 9 to 3 plane while you watch what moves too much.
Pay close attention to the rod ends and the pitman arm. A good diagnostic tool for
suspension is a cheap digital camera that can make movies, Attach it under the van
pointed at a suspected component. Go for a ride to a spot you know causes it to happen and start the camera rolling. A big c clamp makes a good mount for the camera.
Old Nov 25, 2007 | 07:47 PM
RustyTrustyF150's Avatar
RustyTrustyF150
Exclamation
Have your front wheels balanced . I have a 74 f350 with the 16 inch split rims and it did the front wheel shake thing . Well i had different tires put on and had the wheels balanced and one of the rims is really bad to balance so it is on the back for now . Some places dont or cant balance these but others can . Another idea is how good are the shocks ?
Old Nov 26, 2007 | 06:33 PM
johnathon's Avatar
johnathon
Hi shocks are new, in kicking around older posts someone suggested increasing toe out.I looked over all front end parts to see if anything seemed loose or worn. Except for the tires being half worn eveything is tight , so I increased toe out a smidge , bingo not a hint of nervousness and no shake period. Thanks for the input
nwjones18
Sep 20, 2016 08:57 AM
Wes Shaver
2004 - 2008 F150
Nov 28, 2015 09:03 PM
Bigd1975
2004 - 2008 F150
Sep 24, 2015 11:29 AM
ssolid
Mar 10, 2014 12:23 AM
bronco 1996 16 year old
Jun 5, 2003 12:43 AM
