Ignition Problem
Old Feb 17, 2002 | 02:22 PM
riverrat93's Avatar
riverrat93
Ignition Problem
I just recently hooked up my new engine and I cannot get a spark from the plugs. I tested everything I could think of with a light tester and I am getting power to everything but still no spark to the plugs.The truck is an 85 with a 300.If anyone has a suggestion it would be appreciated.
Old Feb 17, 2002 | 09:48 PM
wtroger's Avatar
wtroger
Ignition Problem
Are you getting spark out of the coil. If so cap or rotor is bad. Is there power to the red wire on the coil. If not check connections. Is this a duraspark or a tfi? Need a little more info.
Old Feb 17, 2002 | 10:02 PM
riverrat93's Avatar
riverrat93
Post Ignition Problem
It is a tfi ignition .The cap ,rotor ,distributour and coil are all new so are the plugs and wires.I had the module tested and it tested good.I get power to the coil but thats it nothing to the plugs.
Old Feb 18, 2002 | 08:42 AM
wtroger's Avatar
wtroger
Ignition Problem
Sounds like pickup coil inside distributor is bad. If it is a new distributor take it back.
Old Feb 18, 2002 | 12:01 PM
swirk's Avatar
swirk
Ignition Problem
ymirr
Apr 6, 2017 07:42 PM
HelenB
May 17, 2016 04:38 PM
1999stroke
Jan 31, 2014 03:29 PM
mrmac40
17
Aug 29, 2003 05:19 PM
JTF
Aerostar
Feb 10, 2003 04:23 AM
