Wipers Wont Stop
Old Nov 22, 2007 | 04:05 PM
Bruinzfan's Avatar
Bruinzfan
Wipers Wont Stop
Has anyone had the problem where their front wipers wont stop. They will operate on high and low. No intermittant. Even when i pulled the 15 amp fuse they kept going. I went back to the book and found a 30 amp fuse. Pulled that and they stop. I have been working too much to look for the solution. My electrical knowledge tells me it is probably a welded contact in a relay. Thanks for your thoughts.
Keith
Old Nov 22, 2007 | 10:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
Weird...I'd follow your hunch and find and replace the relay.
Old Nov 23, 2007 | 09:39 AM
Dereck's Avatar
Dereck
Hi Kieth 8898
There is a recall on early Excursions for a problem with the intermitant function in the wiper motor, on occasions the wiper motor can catch fire.
The fix is to replace the wiper motor cover with an updated new one, the dealer will do this free of charge.
I suggest maybe a trip to the dealer first to check out whther yours is covered by the recall.
Regards
Dereck
Old Nov 23, 2007 | 10:46 AM
Bruinzfan's Avatar
Bruinzfan
Thank you for you tip on the recall. I will check that out.
Old Nov 23, 2007 | 02:18 PM
Monsta's Avatar
Monsta
Sit. Stay.
That recall only affected 2001 and older. And the problem was that there was NO function not continuous function. Still wouldn't hurt to check with the dealer.
Old Nov 23, 2007 | 05:20 PM
Dereck's Avatar
Dereck
Hi Monsta
The wipers on my Excursion would occasionally continue to run and when they did stop would sometimes park in the up position.
Regards
Dereck
Old Mar 22, 2010 | 10:23 AM
Corndwg01's Avatar
Corndwg01
I know I'm digging up an old post here, but didn't want to start a new one for the same problem. I have the same truck as Keith, an 02 Excursion. I'm currently having the same problem too. The wipers want to run constantly, even with the key out and I have no int wipers. Pulling the 15A fuse did nothing. Pulling the 30A relay will get them to stop. I swapped the relay out with another 30A and still have the same problem. So now what?!
Old Mar 22, 2010 | 06:28 PM
Corndwg01's Avatar
Corndwg01
Just did some more troubleshooting. With the switch on the column unplugged, the wipers still work on their own. I'm guessing this means it's the motor???
Old Mar 25, 2010 | 09:13 PM
Corndwg01's Avatar
Corndwg01
Bump...
I still haven't gotten anywhere with this thing. I know it's not a super common problem, but I've read a couple of posts here and there with other people having this issue. No one ever says what the resolution was though.
Old Mar 27, 2010 | 06:47 PM
fordtech08's Avatar
fordtech08
definetly sounds like your motor cover or a bad motor, I don't think the recall is still open though
Old Mar 27, 2010 | 08:44 PM
Corndwg01's Avatar
Corndwg01
Yep, finally got it fixed today with a new motor. Glad it wasn't the stupid GEM.
Old Mar 27, 2010 | 08:45 PM
fordtech08's Avatar
fordtech08
sorry I didn't help earlier just saw your message
Old Mar 27, 2010 | 11:05 PM
Corndwg01's Avatar
Corndwg01
No problem. It's fixed now, that's all that matters.
Dalozsw
Electrical Systems/Wiring
Feb 8, 2015 07:19 AM
lightwait
Dec 8, 2012 11:39 AM
Bigbird1960
Sep 11, 2010 09:39 PM
bigrockbronco
Sep 18, 2009 06:03 PM
luvemhot
Oct 13, 2006 08:56 PM
