Gettin Budd wheels off?
Old Nov 22, 2007 | 12:20 PM
Dstosh's Avatar
Dstosh
Is there special trick to getting the front Budd wheels off? The truck is a 96 F-350 Dump 4x4 Diesel. I tried the old fashion way of beating the tire with a sledge and that didn't seem to help. Air Hammer Didnt really help either. Are they just rusted on?
Thanks in advance,
Derek
Old Nov 22, 2007 | 12:27 PM
c00nhunterjoe's Avatar
c00nhunterjoe
thoses would be stuck, rotate the rim and wack it from the back side till it comes off, then antisieze it before re-installing
Old Nov 22, 2007 | 12:31 PM
westtntrucker's Avatar
westtntrucker
Warm the rim up around the hub area (no torch). If it is very cold the aluminum will shrink and be a bugger to get off the hub.
Old Nov 22, 2007 | 08:59 PM
tjbeggs's Avatar
tjbeggs
yep what Joe said then if that doesn't work some have had luck with putting the nuts on loose then driving the truck in the drive way till they pop loose (so at your own risk!)
Old Nov 22, 2007 | 09:20 PM
97REDPSD's Avatar
97REDPSD
leave wheel lugs nuts loose and rock truck side to side sometime it come loose or drive it like TJ said.
Old Nov 23, 2007 | 07:09 PM
Dstosh's Avatar
Dstosh
I got em today. Had to use a torch. Destroyed a hub in the process. Oh well Live and Learn
Old Nov 23, 2007 | 10:08 PM
c00nhunterjoe
ouch, never busted a hub getting them off. that sucks.
shop_built
Jul 12, 2016 09:02 PM
opkomdalen
Feb 26, 2012 08:32 AM
fire & smoke
21
Dec 10, 2011 11:41 AM
2speed
Large Truck
Mar 16, 2011 08:56 AM
millenims_disciple
May 10, 2009 01:01 AM
