carb question
Old Feb 21, 2002 | 04:54 PM
captntim's Avatar
captntim
carb question
[updated:LAST EDITED ON 21-Feb-02 AT 05:54 PM (EST)]hi there...On my carburator, there is a small electric motor (I think) mounted on the driver's side of the carb. lately, it had been running very rough when cold, and this morning, it would not idle no matter what I did. I experimented with a few things, and ended up disconnecting this electric motor...the engine smoothed out and runs great. what is the purpose for this and why would it cause this problem?
thanks for the help
captntim
'86F150 4x4 300I6 SWB NP205 4speed 3.08s
Old Feb 21, 2002 | 06:55 PM
Nod's Avatar
Nod
carb question
captntim, I had the same problem with my carb,I did the same thing you did and it runs great. I have no clue what the electric sylenoid-motor did all I know is it dont do anything now!!
"bowties in the rearview mirror"
Old Feb 21, 2002 | 07:34 PM
captntim's Avatar
captntim
carb question
ha...that's great..thanks for the response.
captntim
Old Feb 22, 2002 | 12:53 AM
tetraruby's Avatar
tetraruby
carb question
I know your carbs are a little different than mine ('79) but, there's an "idle stop solenoid" on some of them. The idle stop energizes effectively setting the idle. When you turn off the key it allows the throttle to close completely to prevent dieseling. Not sure if this is the same on your feed back carb. Doesn't make sense...
Old Feb 22, 2002 | 11:35 AM
captntim's Avatar
captntim
carb question
I know what you mean..I also have an idle control solenoid and incadentally, that dosen't work either (hmmmm...). I did replace it, that was a waste of money, perhaps I have some issues with the computer? This other device I was talking about is part of the "feedback" carb set up, but I'm not sure what it does
captntim
'86 F150 300I6 4x4 SWB NP205 4speed 3.08s
Old Feb 22, 2002 | 11:37 PM
Vampiro's Avatar
Vampiro
carb question
if it works better without it keep it like that. does it deisle tho after trun off? if not, id leave it disconnected. heck i don't know what it does, but w/e it is i bet it's gonna be replaced anyways
Old Feb 23, 2002 | 12:18 PM
brown 4x4's Avatar
brown 4x4
carb question
At rear of the carb is the idle speed control motor, which is supposed to adjust your idle in different conditions. On the driver's side of the carb is the feedback soleniod. I think this is supposed to control part of the fuel mixture.
1986 F-150 4x4 300 I6 NP435
Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint
Old Feb 24, 2002 | 04:19 PM
midnightrunner's Avatar
midnightrunner
carb question
Macke
Nov 7, 2014 09:01 PM
oldracerjones
Jul 18, 2014 11:18 AM
Duksrule
Jun 16, 2009 11:36 AM
welder691
13
Jun 20, 2007 05:43 AM
captntim
Offroad & 4x4
Oct 22, 2001 11:30 AM
