intermittent fuel pump
Old Nov 21, 2007 | 02:30 PM
molsson55's Avatar
molsson55
my fuel pump stopped working 3 wks ago then after a couple of hours started working again. it ran for three wks after i replaced the fuel filter,and egr valve
now it cut out again last night but started again this afternoon drove it home it wanted to stall the whole way.i made it home shut off the engine and i have no response from the fuel pump again.it will start run rough then cut out when i give it gas.i get no sound from the fuel pump.its a 95 ford explorer xlt with 160,000 miles any ideas?
Thanks
Mark
Old Nov 21, 2007 | 02:38 PM
Backin72's Avatar
Backin72
Check the fuel pump relay first. When they go, they usually are intermittent to begin with then just die. Swap out the fuel pump relay with one that isn't critical at the moment. There should be about 3 or 4 of them that control different things. They are located under the hood.
Old Nov 21, 2007 | 03:17 PM
molsson55's Avatar
molsson55
i checked the different fuses still no pump noise or start. i just put the diagnostic tool on it and got the code for "fuel pump circuit open pcm to motor"
Old Nov 21, 2007 | 04:08 PM
Backin72's Avatar
Backin72
Relay, not fuse.
Old Nov 21, 2007 | 04:09 PM
Bear River's Avatar
Bear River
Former ******
He didn't say fuses, he said relays. There are a group of relays that control things lie the AC, fuel pump,etc. Just switch them around and see what you get. You can get them cheaply at the local parts store. The best replacements are the ones with all the pins, so they can be used to replace any of the relays if needed.
Old Nov 21, 2007 | 04:38 PM
molsson55's Avatar
molsson55
right i checked the relays they are fine sorry.
Old Nov 21, 2007 | 04:42 PM
molsson55's Avatar
molsson55
relays check out fine . code reader comes up with" open circuit pcm to motor " . what could that Be?
Old Nov 21, 2007 | 04:46 PM
molsson55's Avatar
molsson55
" fuel pump circuit open pcm to motor " is what the code reader comes up with.
Old Nov 21, 2007 | 10:35 PM
mrshorty's Avatar
mrshorty
The fuse and the relay are certainly not the entire fuel pump circuit. On my '92, I had a bad connection somewhere between the fuse and the relay. If you've decided that the fuse and relay are good, then it's time to get out a voltmeter and a wiring diagram, and determine where the break in the circuit is. When I do it, I start at the battery and work down the circuit until the voltage drops. Where the voltage drop is is where the problem is. Be sure to ground the fuel pump test lead so the fuel pump relay will be closed.
Old Nov 22, 2007 | 06:17 AM
marragtop's Avatar
marragtop
Check and make sure the connection on the bottom of the inertia switch is tight. That was the problem on my 95, and was I almost ready to put a fuel pump in it until I read thru the wiring diagram. Many people just check to see if the inertia switch is popped, but you have to also make sure the connection at the bottom is good. The inertia switch is also a good place to use a test light. If you have juice to that, then the problem is between the inertia switch and the pump. This would rule out the PCM and FP relays and the ignition switch.
Old Nov 27, 2007 | 08:06 AM
gibsonj's Avatar
gibsonj
The next time the FP quits, whack the bottom of the fuel tank with a rubber mallet or similar. Often, the vibration will "re-energize" the FP if the short is there. If you can hear the pump whirl when you turn the key to on then, its probably a short at the pump, and you'll have to drop the tank.
Old Dec 8, 2007 | 12:14 PM
molsson55's Avatar
molsson55
fuel pump
thanks for the advice guys.
now i need a few days off with decent weather.
95 ford explore xlt
Old Dec 18, 2007 | 02:23 PM
duker1961's Avatar
duker1961
I have the exact problem with my 94 Explorer 4.0 auto. It will run fine for months and then just leave me stranded. Sometimes it will start in minutes. Sometimes it takes hours. When it doesn't run, the fuel pump is not energizing. I can tell as soon as I turn the key if it's going to run or not.
I've replaced the relay (I carry a spare) and checked the connections but I haven't found a problem. It's so intermitent I won't take it to the shop. I have noticed it seems to behave better in warmer weather.
Please post again if you find a problem. I'd really love to fix this thing!!
Old Dec 20, 2007 | 10:28 AM
gibsonj's Avatar
gibsonj
with it being intermittant, I'd bet it was a short at the FP. Probably going to have to drop the tank--not a bad job, provided you plan it right and you didn't just fill up.
KJNDIVER
37
Aug 19, 2020 11:24 PM
Kierobi
28
May 1, 2015 10:40 PM
AAAAAHAB
16
Feb 22, 2015 12:18 PM
FlaHawg
Aerostar
Nov 9, 2014 10:01 PM
