radio help
Old Nov 21, 2007 | 11:39 AM
Dan Taylor's Avatar
Dan Taylor
radio help
any1 have the correct wire colors and such for hooking up a new radio? i got it so the radio will go on but i cant seem to get power to the speakers. i got a 95 f150
Old Nov 21, 2007 | 12:03 PM
Virto's Avatar
Virto
Constant 12V+ Green/Purple
Switched 12V+ Black/Pink
Ground Black/Green
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 6" x 8" Doors
Left Front (+) Gray/Light Blue
Left Front (-) Tan/Yellow
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 6" x 8" Rear Corners
Left Rear (+) Orange/Light Green
Left Rear (-) Light Blue/White
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
This SHOULD be correct. Personally, I'd have used a 10 dollar harness as opposed to cutting into the factory wiring, unless you're fixing someone elses job.
Old Nov 21, 2007 | 01:30 PM
Dan Taylor's Avatar
Dan Taylor
ya im fixing a job that some1 did to the truck beofre i owned it. thanks alot ill go see if this works
Old Nov 21, 2007 | 03:15 PM
Dan Taylor's Avatar
Dan Taylor
all the wires are hooked up correct. when i turn the car on i hear the speaker make a small sound and the radio turns on. how ever no sound is coming out. any ideas?
Old Nov 21, 2007 | 03:17 PM
Virto's Avatar
Virto
Is it a factory radio or an aftermarket one? Have you confirmed it works?
Old Nov 21, 2007 | 05:22 PM
subford's Avatar
subford
Note that pin #1 on C257 is logic mute, with out a wire on this pin there will be no sound but the radio will look like it is working OK.
Old Nov 21, 2007 | 09:18 PM
Dan Taylor's Avatar
Dan Taylor
what cable should i hook that mute pin too? all the cables on the radio are all taken. do i just attach it to the other ground all ready connected to the radio?
Old Nov 21, 2007 | 11:47 PM
subford's Avatar
subford
Are you saying you do not ahave a wire for pin#1? If you are hooking up with the Amp system it is the Blue wire coming from the Amp.
If not then yes hook it to the ground wire also (Black wire with a green stripe).
Old Nov 22, 2007 | 05:01 AM
Skandocious's Avatar
Skandocious
This website also has a lot of great information for installing radios, including diagrams with wire colors:
http://www.installdr.com/
Old Nov 22, 2007 | 10:33 AM
Dan Taylor's Avatar
Dan Taylor
ok i got all the wires connected that the radio has. on the truck there is still a ground and a full black wire. do i have to connect those to anything? theres like 4 more wires on the truck then the radio has. does that extra ground from the truck need to be on something?
Old Nov 22, 2007 | 10:48 AM
subford's Avatar
subford
The Black wire should go to pin #7 of the gray connector.
Did you look at the two plug diagrams above?
Old Nov 22, 2007 | 11:56 AM
Dan Taylor's Avatar
Dan Taylor
this is what i currently have set up
Radio ------truck
___________________
black-------- black/green
red ---------yellow/black
blue--------- Antenna
yellow -------Green/purple
white --------orange black
green--------- orange green
green/black----- blue white
white/black----- tan/yellow
gray --------white/green
gray/black------ dark green/orange
purple------ pink/blue
purple/black----- brown/pink
NONE ----- black green
NONE ------ black
NONE -------- blue/red
NONE------ pink/green
Old Nov 22, 2007 | 12:12 PM
subford's Avatar
subford
Radio ------truck
___________________
NONE ------ black
The RADIO does not look like a Ford radio.
What are you working with?
Brand?
Model?
Do you have a manual with it?
If so does it tell what wire color does what?
Old Nov 22, 2007 | 12:21 PM
Dan Taylor's Avatar
Dan Taylor
it is a sony radio i just bought and the wiring is all set up how it told me to. i still have that other ground wire or that solid black wire that isnt hooked up which i think may be the problem. i got this radio http://www.bestbuy.com/site/olspage....=1184369165921
Old Nov 22, 2007 | 12:38 PM
quicklook2's Avatar
quicklook2
this is exactly why i use adaptors when installing aftermarket receivers.
10 minutes later and i am done.
