radio help
Old Nov 22, 2007 | 12:39 PM
Dan Taylor's Avatar
Dan Taylor
i would have used an adaptor but the guy before me ripped the radio out before and all the wires were cut
Old Nov 22, 2007 | 12:52 PM
quicklook2's Avatar
quicklook2
the one time i had that happen to me, the radio in a ford vehicle was stolen, i went to a junkyard and got the ford harness and matched that up and than used an adapter on the sftermarket receiver.
maybe this would be the way you should go.
Old Nov 22, 2007 | 12:55 PM
handyman43358's Avatar
handyman43358
You might be further ahead to hit a junkyard and cut the plugs out of another Ford vehicle. They used the same plugs from like 87 up to 96 I believe on most models.
Old Nov 22, 2007 | 01:27 PM
subford's Avatar
subford
It should wire like this, I hope you did not blow something with the orange/black wire on a speaker wire.
Radio
------ truck
___________________
black-------- black/green Ground G200
red ---------yellow/black
blue--------- Antenna
yellow -------Green/purple
white --------orange / GREEN
green--------- pink/green
green/black----- tan/yellow
white/black----- blue / white
gray --------white/green
gray/black------ dark green/orange
purple------ pink/blue
purple/black----- brown/pink
NONE ----- black green Ground G200
NONE ------ black Ground G201
NONE -------- blue/red Lumination not used
NONE------ Orange / black dimming not used
Old Nov 22, 2007 | 01:30 PM
quicklook2's Avatar
quicklook2
that sounds like a plan.
hey, handyman, how is life treating you?
working all the time i bet.
happy thanksgiving!
Old Nov 22, 2007 | 02:01 PM
Dan Taylor's Avatar
Dan Taylor
wires are set up to how you posted. still no sound. what should i do next. i made sure every wire was properly connected and all fuses are ok. i dont hear any sound at all coming from the speakers
Old Nov 22, 2007 | 02:04 PM
subford's Avatar
subford
Did you plug in the antenna cable in the back of the radio?
Also did you check to see if there are any speakers installed, they may have removed them too.
Check each speaker wire combo with a 1.5 Volt battery to see if they work.
Old Nov 22, 2007 | 02:33 PM
quicklook2's Avatar
quicklook2
are you sure the sony is a working unit?
Old Nov 22, 2007 | 03:16 PM
Dan Taylor's Avatar
Dan Taylor
checked every speaker. they all work. the sony is brand new and all fuses are in working order. i hate this game
mrgn_mtt's Avatar
mrgn_mtt
The easiest thing to do is just go to a car sterio place and get an adapter that plugs right into the old harness. its got all the standard colors coming out the back.
Old Nov 22, 2007 | 03:24 PM
Dan Taylor's Avatar
Dan Taylor
i dont got the old harness. should i just get a old harness at a junk yard hook that up then buy the adaptor? i dont see why it isnt working though. could i have boughten a broken head unit? im trying to find some1 a sony and see if theirs works in mine
Old Nov 22, 2007 | 04:22 PM
subford's Avatar
subford
Did you do this as the installation paper states?
Old Nov 22, 2007 | 04:39 PM
  #28
Dan Taylor's Avatar
Dan Taylor
i dont got a reset switch there. i think i posted the wrong radio up. the model number of mine is CDX-GT11W
