Side gapping sparkplugs!
Old Mar 10, 2002 | 11:35 PM
DrkPhanstm's Avatar
DrkPhanstm
Well this weekend I needed to change my oil, so I thought while I was at it I would buy some new motocraft plugs and try sidegapping them. So far ( 150mi ) I'm very pleased with the results! cruising on the highway @ 70mph I used to slow to 65mph going up hills, now I can maintain speed, and even accelerate a tad up them. Around town I noticed no difference though. Initial mpg results seem to have helped a tad. But with only a single 150mi test run... I have no results to give.
I must admit though, I'm not sure if the small increase I've had is due soley to the sidegapping; or the fact that when the dealer changed installed new plugs that they didnt have the #6 plug tightened all the way! Heh, so thats what that ticking noise was....
Either way, for a freebie... I'll deffenitly be sidegapping all my plugs from now on. I'll get some mileage results up after I've got enough miles driven
Old Mar 11, 2002 | 08:32 AM
brianwbo's Avatar
brianwbo
Ok Just a quick question.........What is sidegapping?
Old Mar 11, 2002 | 08:38 AM
Vampiro's Avatar
Vampiro
im wondering to this too myself
Old Mar 11, 2002 | 11:50 AM
tetraruby's Avatar
tetraruby
I saw a short lived gain in performance, but it seemed the plugs didn't last too long either. Didn't seem to do whole lot for my rig. For those of you wondering, there's a good explanation at a website that I can't recall the address....if you do a search for "sparkplugs" under the '73-'79 forum it's in there from about six months ago - it's easy to find, just did it about two weeks ago for someone else. Should have saved the link - oh well....
Old Mar 11, 2002 | 11:55 AM
tetraruby's Avatar
tetraruby
Sorry about that, thread was in this forum from last Sept. Here it is:
http://performanceunlimited.com/illustrations/sparkplugs.html
Old Mar 12, 2002 | 07:09 AM
chip58's Avatar
chip58
I found sidegapped plugs wore out too soon to be worth the trouble. I finally settled with platinums and an MSD high output coil. Very happy.
Old Mar 12, 2002 | 10:30 AM
classicfordluvr's Avatar
classicfordluvr
Hey everyone! It has been a VERY long time since I've been around, mainly since my truck has remained out of commission since I hit the deer with it last July. But it's going back on the road next week finally. Best part is I put it all back together myself. I thought I'd put in my 2 cents on side-gapping, since I did it to my car last summer after the truck got iced. With the side-gapping, and the same old tuneup I always do to it (74 351W 2V) I went from it's usual 14 to 16mpg on the highway to 20mpg on a 900 mile run. I wouldn't say the performance difference was really noticeable, but it did have plenty of grunt on some of those big hills between NW Ontario and Indiana. (mainly in MN and northern Wisc.) I plan on doing it to the truck as soon as the new Platinums that I had installed about 100 miles before the incident with the deer are done. I didn't see any performance boost from the platinums, so cheap sidegappers will probably be better. A Dremel multi-tool with a little cut-off wheel is perfect for cutting the plugs. Does a nice smooth job. Have about 7000 miles on the ones in my car right now and they still look good enough to run until spring.
:-X11
Old Mar 12, 2002 | 03:18 PM
DrkPhanstm's Avatar
DrkPhanstm
Ya... the only down side to sidegapping is the shorter plug life. about 10,000mi is what seems to be average from what I've read online. But motocrafts are cheap, and easy to change on the 300 so I'm not too worried about that. The ability to keep speed going up hills on the highway is well worth it to me.
I'm planning on getting a MSD6a, TFI coil, and probably new cap/rolot/wires to go with it. But thats around $200... This little venture cost me $9, heh I can afford that right now
Old Mar 12, 2002 | 10:33 PM
cw50must's Avatar
cw50must
MtTheJeffro
15
Jul 13, 2015 06:51 PM
44nneedit
Feb 6, 2007 02:04 PM
broncr
May 11, 2003 10:40 PM
mikes66
Nite, Nascar & Other Limited Edition Ford Trucks
May 1, 2001 11:30 PM
studfisherman
Jul 6, 2000 05:23 AM
