axle codes
Old Nov 21, 2007 | 05:38 AM
bowkill's Avatar
bowkill
axle codes
I did a search and can't find the info I am looking for. Mydoor sticker says that i have axle code 26. My window sticker says that I have a 3.73 regular axle. Just wanted to make sure this is correct as I am trying to get my speedo correct. Thanks for any help
Old Nov 21, 2007 | 08:17 AM
MBBFord's Avatar
MBBFord
27 — 3.31 non-limited slip (F-250)
26 — 3.73 non-limited slip (F-250)
I don't know why you'd have that on a F150.......
Check the rear axle bolt cover there will be a metal tag on the passengers side.
The numbers closest to the bolt holding the tag on will be your gear ratio. So if it shows 3L73, then you have 3.73 gears w/ limited slip.
These are the codes for F150s:
19 — 3.55 non-limited slip (F-150, Econoline)
17 — 3.31 non-limited slip (F150, Econoline)
H9 — 3.55 limited slip (F-150, F-250)
B6 — 3.73 limited slip (F-150, F-250)
Old Nov 21, 2007 | 01:10 PM
1saxman's Avatar
1saxman
The '07s must go by the F-250 codes, because I have a 3.31 in my V6 5-speed F-150, and the axle code is 27.
Old Nov 21, 2007 | 03:44 PM
bowkill's Avatar
bowkill
Thanks for the info. The truck is a 2004 F150. I checked the meta tag on the passanger side. Some numbers were hidden by the bolt head I guess. The tag read
V956F
73 75 3J23
On the driver side, the tag said
EHP OIL ONLY
Y75W900FEHP
thanks again
Old Nov 22, 2007 | 08:47 AM
Fordchic86's Avatar
Fordchic86
ignore post, sorry wrong place
Old Nov 22, 2007 | 08:50 AM
MBBFord's Avatar
MBBFord
Talking
Originally Posted by bowkill
V956F
73 75 3J23
EHP OIL ONLY
Y75W900FEHP
thanks again
First number shows you have 3.73 gears. Yes the bolt does block a little, but if you could tell if there is a . or L right before the 73, then that'd tell you if you have limited slip or not. The L stands for LS, and the . means open.
According to your door code it is open.
I didn't know they offered 3.73 open differentials...... Then too I haven't been looking into much since 04.
Bottom numbers- use 75w90 gear oil.
Edit: Wow 5,000 post! I'm supprised ya'll didn't tell me to shut up yet.
vaporhp
Apr 5, 2025 11:45 AM
boggerted
16
Feb 17, 2019 12:50 PM
cowmilker08
Feb 26, 2011 04:06 PM
Techfree
2004 - 2008 F150
Dec 20, 2010 07:58 PM
Dave Cooley
Jun 8, 1999 08:22 PM
