Ranger axle code 97
Oct 27, 2006 | 12:46 AM
3rd Gear
Ranger axle code 97
Hi
I have a 2000 Ranger
The door sticker has an axle code 97
Any one know the gear ratio?
Thanks
Oct 27, 2006 | 02:28 PM
2000 Ranger Axle and Transmission Codes
Axle Codes
The following lists the gear ratios on axles.
l 86 — 3.73 non-limited slip, 2.5L, 3.0L engines, 4x2.
l 87 — 4.10 non-limited slip, 2.5L, 4x2.
l 89 — 4.56 non-limited slip, 2.5L, 3.0L engines, 4x2.
l F6 — 3.73 limited slip, 2.5L, 3.0L engines, 4x2.
l F7 — 4.10 limited slip, 2.5L, 3.0L engines, 4x2.
l 95 — 3.55 non-limited slip, 4.0L engine, 4x2.
l R5 — 3.55 limited slip, 4.0L engine, 4x2.
l 86 — 3.73 non-limited slip, 3.0L engine, 4x4.
l 87 — 4.10 non-limited slip, 3.0L engine, 4x4.
l F6 — 3.73 limited slip, 3.0L engine, 4x4.
l F7 — 4.10 limited slip, 3.0L engine, 4x4.
l 97 — 4.10 non-limited slip, 3.0L engine, 4x4.
l R7 — 4.10 limited slip, 3.0L engine, 4x4.
l 96 — 3.73 non-limited slip, 4.0L engine, 4x4.
l 97 — 4.10 non-limited slip, 4.0L engine, 4x4.
l R6 — 3.73 limited slip, 4.0L engine, 4x4.
l R7 — 4.10 limited slip, 4.0L engine, 4x4.
Transmission Codes
l T — Four-speed automatic (A4LD/4R44E).
l D — Five-speed automatic (A5LD/5R55E).
l M — Five-speed manual (M5R1).
l H — Single speed (electric).
Apr 23, 2012 | 11:18 AM
axle codes
Project SHO89, Can you provide the same info for 2006 Ranger??
Do you have a link for decoder for later model Ranger data plates ??
Apr 24, 2012 | 06:05 AM
Apr 24, 2012 | 11:54 PM
axle code 97
project SHO89. Thanks for all your help. I have been looking for that stuff for days. Didn't want to bother the local dealer. All this was needed as I am looking to buy a Ranger within the next couple of weeks.
Thanks again. Ken Liden
Jan 27, 2023 | 06:14 PM
old thread revived :
I just bought a 2011 Ranger 2.3L Auto axle code 97
it feels like a 4.10 at 55mph
is this the case ?
Feb 19, 2023 | 05:01 AM
Quote:
Originally Posted by
BROWN DOG KTM
is this the case ?
Door code 97 is a 8.8 open differential 4.10 28 spline on my 2011 Ranger 2.3L Automatic.
I opened it up to find an excessive noise.
turned out to be the outer pinion bearing.
Master Install kit & a Yukon DuraGrip locking differential is ordered
Apr 4, 2025 | 12:39 PM
BROWN DOG KTM
i have a 2004 4x4 4.0 with the same 97 axel code, is it the same spline as yours?
Apr 5, 2025 | 11:45 AM
jrks
i would think your 2004 would be 28 spline too BUT my 2011 is rear disc brakes so it could be different on your older drum brake application
DannyP
Jan 27, 2025 10:33 AM
97 ranger 1
1983 - 2012 Ranger & B-Series
Jun 26, 2005 07:04 PM
billexpedition
Jun 15, 2005 04:10 AM
jonrer
Nov 25, 2003 07:26 PM
Dangme
Oct 13, 2001 08:45 AM
2000 ,
2001 ,
2006 ,
30l ,
373 ,
4x2 ,
97 ,
automatic ,
axcel ,
axle ,
code ,
codes ,
ford ,
ranger ,
ratio ,
truck
