Sponsored by: Auxito
Heater Core Replacement
Old Nov 21, 2007 | 04:01 AM
50th ann's Avatar
50th ann
My heater core is leaking. It looks like that thing is deep under the dashboard. How much of a job is it to get to it? Got any tricks that might help?
Old Nov 21, 2007 | 09:42 AM
KingRanchMan02's Avatar
KingRanchMan02
This will be a daunting task for the holiday weekend. Click here for instuctions. Good luck!
Old Nov 21, 2007 | 10:18 AM
50th ann's Avatar
50th ann
Heater Core
I thought so. I'm going to get a bigger hammer.
Old Nov 21, 2007 | 10:48 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
A sawzall would make it so much easier! Just watch out for that airbag
Old Nov 21, 2007 | 08:48 PM
Wilber15's Avatar
Wilber15
Haha, you have to take the dash out.... Good luck! You might even have to seperate or remove the entire evaporator housing to sneak that bugger out. So you'll need to evacuate the AC lines(and I'm guessing you don't have the proper tools for this) in order to get that housing far enough from the fire wall to get that core out.
Old Nov 22, 2007 | 12:29 PM
oddballish's Avatar
oddballish
Heater core replacement
First how bad is the leak? If its bad good luck.If it is a small one ( pin hole ) check with a GOOD radiator shop and see if the have some good stop leak not the OTC stuf.Worst thing that could happen is you still have to change it latter,hopfully in the sumer when you dont need it.
Old Nov 22, 2007 | 05:04 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
No, you don't have to touch the AC system to replace the heater core. You don't move the housing at all. You pull the dash out, and the top of the housing unscrews and it's all right there.
Old Nov 22, 2007 | 06:55 PM
Wilber15's Avatar
Wilber15
I've never done an older f-150. I've only done an 05' and to get the heater housing far enough from the firewall to clear the core lines, you need to disconnect the AC lines. I helped a buddy at work pull the dash for a 98' f-150 but wasn't around when he actually pulled the core, so i wasn't sure.
Old Nov 22, 2007 | 09:18 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
With these trucks ('97-'03), you disconnect the hoses in the engine bay, and pull the heater core from the cab. It's quite easy once you spend 9 hours taking the dash out
Old Nov 22, 2007 | 09:33 PM
Wilber15's Avatar
Wilber15
I know how they come out....I just didn't know if you had to loosen the housing to get it out or not. I do know you can get alot of core's out without actually taking the evaporator housing out.
Old Nov 23, 2007 | 05:13 AM
50th ann's Avatar
50th ann
Leaky Core
The leak and smell in the cab has been starting and stopping for months now. At least three times now. At first I thought the core rusted out but once that happens the leak dones't stop - Right? The other night parked in my garage there was almost a steady stream leaking. A fast drip that leaked about 8 OZ. The air conditioner was not on so it was not condensation. For at least two days now no leak or smell. Could it be the seals at the hose connectors. I have never seen one apart so I don't know what the possibilities are. Changing the hoses sounds like alot less fun but much eaiser.
What do you think? But the way living in Florida I don't need the heat so much but keeping the coolant in the truck is a good idea anyway.
Old Nov 23, 2007 | 10:00 AM
Club Wagon's Avatar
Club Wagon
That's good to know. Sounds like a dreadful job anyway & is a good reason to change antifreeze regularly so as to maintain a high level of anticorrosives to try to prevent heater core failure.
Readers should note that Haynes '97-'03 disagrees. Under "Heater core - removal and installation" step 1 states "have the air conditioning system discharged" & step 4 states "Disconnect and plug the evaporator lines".
I went through a couple of aluminum heater cores in my E150 & learned 2 things. First, I hate the Quick Connectors & ended up eliminating them & 2 found aftermarket aluminum cores were even crumbier than OEM, but after searching around found a soldered brass replacement that was actually cheaper!
Old Nov 23, 2007 | 11:08 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The Haynes manual is wrong. I used a combination of the Haynes and the link that was posted earlier. I never got near any part of the AC system. The only reason I can see to drain and remove the AC lines would be for some extra clearance under the hood to reach the back of the firewall. But if my huge hands can reach the firewall, anyone else can as well.
Old Nov 23, 2007 | 09:55 PM
Club Wagon's Avatar
Club Wagon
As I said "That's good to know" & IMO its also good to know what such a common reference as Haynes said. I can not so easily dismiss Wilber15 & Haynes or positively ID which models/years might & might not need the evaporator disconnected. FORD has thrown out a variety of curves as the recent debate about normal & reverse threads on fan clutches illustrated.
Haynes also tells you to drain antifreeze & remove the upper radiator hose in order to remove the fan shroud during fan clutch replacement. I found the fan shroud both flexible & tough enough to wrestle out w/o touching the radiator hose on my '98.
The important point I was trying to make was that its become apparent that these heater cores are fragile, are a proven PITA to replace & are likely to benefit by regular antifreeze changes. IMO changing antifreeze is frequently overlooked & far more important as the number of aluminum components increases. I'll bet my Dad's dealer maintained '98 Cream Puff never had the antifreeze changed, even though FORD specifies 4 year intervals for it's 'premium' antifreeze.
However, we can safely dismiss your "sawzall" suggestion as being absolutely "wrong".
Old Nov 23, 2007 | 10:35 PM
Club Wagon's Avatar
Club Wagon
IMO you've got a problem if you can not distinguish condensation from antifreeze! IMO if you're running water coolant only, w/o the benefits of antifreeze, you're begging for corrosion problems like "the core rusted out".
IMO "a steady stream leaking...about 8 OZ" should be fairly easy to track down & positively ID. To help you diagnose, if running w/o antifreeze: condensate will be cool, while coolant will be hot. Note: the AC will run in any position except Off, Floor OR Panel. On a 10 YO the leak could be from a variety of sources. Afraid you're going to need to look at it closer & track it down. The heat/AC housing apparently catches condensation or leaking antifreeze & drains it at the same point. Certain AC faults cause an evaporator to ice up, resulting in a quantity of water/melting after shut down, often accompanied by a stale/swampy odor. You need to monitor your coolant level closely.
