460 f150
Old Nov 21, 2007 | 02:20 AM
Ford-Trucker84537's Avatar
Ford-Trucker84537
460 f150
i have an 1987 f.150 and the 351 windsor crapped out. What modifications will i have to make to get the 460 in there and working, i know that i will have to switch out the motor mounts and get a 460 to C6 bell housing, but will the torque converter that is in there now work, if any one has done this swap and has any info id appreciate all the help i can get. Also will my stock front springs hold the big block up or should i get a 2 inch lift spring while im at it, i run 31-10.50s
Old Nov 21, 2007 | 05:43 AM
msb71's Avatar
msb71
Definitly going to have beef up the suspension, the 460 weighs alot more than the 351W, you get some 2WD F-350 coils to hold the weight.
Mike
Old Nov 21, 2007 | 05:53 AM
QA Guy's Avatar
QA Guy
C-6 Bellhousing??? Thats new to me.
Old Nov 21, 2007 | 02:17 PM
Dean88's Avatar
Dean88
Mike
I thought the 460 only weight 150 lbs more. Hmm, maybe I was told wrong.
Old Nov 21, 2007 | 02:25 PM
Virto's Avatar
Virto
150 pounds sitting right on top of those factory (and probably not new) springs is not an insignificant amount of weight. There's a risk of too much suspension travel, plus the weight will take it's toll on all the mounting hardware.
It's doable, but unless you have the 460 sitting around for free it would probably cost less to get a rebuilt 351 than to do all the work to get the 460 crammed in there.
Old Nov 21, 2007 | 04:38 PM
blloyd's Avatar
blloyd
I have an 1988 F-250 with the 351 and I was thinking of doing the same thing.
Would I need to do the same coil change out ??
Old Nov 21, 2007 | 05:04 PM
Ford-Trucker84537
no you should have leaf springs on the f.250
Old Nov 21, 2007 | 06:22 PM
BEWOLD's Avatar
BEWOLD
check out www.landlproducts.com they have conversion kits specificaly for what you want. You'll need a big block transmision, the C6 has an integral bell housing so a small block tranny will not work, different bolt pattern and bell size
79FordBlake
1978 - 1996 Big Bronco
17
Jul 15, 2014 04:51 PM
RockWVU
Dec 27, 2013 01:20 AM
66 sandrail
16
Aug 6, 2011 02:10 PM
duste
Feb 28, 2008 05:04 AM
DeanBob
Aug 1, 2004 07:13 PM
