Coil Springs
Old Aug 5, 2011 | 07:21 PM
66 sandrail's Avatar
66 sandrail
Coil Springs
I have just recently purchased a 78 F150 2WD with a 460 in it. As usual it sits a little low in the front. Is there a set of after market springs, or maybe some from a same year F250 with factory 460 that I could swap out to get the front end up a little?
I would rather not put any of the coil spring lift devices as they don't seem to stay put. Hope some one has a better remedy.
Thanks Leland
Old Aug 5, 2011 | 08:30 PM
HIO Silver's Avatar
HIO Silver
The NPD catalog lists a wide array of springs: stock, HD, w/ AC, and w/AC & HD. Check it out.
Old Aug 5, 2011 | 08:43 PM
66 sandrail
not familiar with NPD, would you send me a web link please?
Old Aug 5, 2011 | 09:00 PM
HIO Silver's Avatar
HIO Silver
Here you go: NPDLink | National Parts Depot
1948-1979 Ford Truck
The list is on page 65, topside inner (where the binding is supposed to be).
Old Aug 5, 2011 | 09:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Become one with the FTE site sponsors.
JBG-Jeff's Bronco Graveyard aka Bronco Graveyard
NPD- you go that one now
BOTP-Blue Oval Truck Parts
Rock Auto-internet sales only
And some non FTE folks, google their web pages and get some free catalogs.
DC-Dennis Carpenter
Truck Shop Orange Ca
LMC
Old Aug 5, 2011 | 09:28 PM
66 sandrail
Thanks a lot for the help!!!
Old Aug 5, 2011 | 09:36 PM
77&79F250's Avatar
77&79F250
Welcome to FTE BTW (by the way).
Yea those twist in metal coil spacers are a POS and the rubber ones are no better.
There is always the JY coil spring option?
Old Aug 5, 2011 | 10:18 PM
66 sandrail
Thanks 77&79F250, I have a JBG cat. and I will look into BOTP, and Rock Auto.
Old Aug 5, 2011 | 10:46 PM
77&79F250's Avatar
77&79F250
I have a stack of all the free ones so I can compare who has what available and what the going rate for certain parts are.
Old Aug 6, 2011 | 08:53 AM
HIO Silver's Avatar
HIO Silver
Same here. They also serve as a price guide on JY or swap meet trips so ya don't overpay (depending on what the part is) or to get a really good deal. For example, I picked up an early Ranger XLT glove box emblem for $2... retail is $30.... and I passed on the deal to fellow FTE'er broncntruckaholic .
Old Aug 6, 2011 | 09:07 AM
ken selvy's Avatar
ken selvy
I added 4 big washers to the bottom of my spring cup to lift my front a little , cost 4 bucks . Worked good .
Old Aug 6, 2011 | 09:08 AM
66 sandrail
I plan on becoming a sponsor, right now I am laid off from work so money is a little tight!!!
Thanks for your help, it has been great!!!
Leland
Old Aug 6, 2011 | 09:12 AM
66 sandrail
Ken..thats a great idea, I have plenty of washer's if not I can cut some from a steel plate!!! Any Idea how thick the washers were?
Thanks Leland
Old Aug 6, 2011 | 09:25 AM
ken selvy's Avatar
ken selvy
1/8 inch , I took the spring off and the bottom spring cup retainer and nut and found washers at ace hardware and slipped them over the eye beam bolt and nut , the washers came up to the top of the nut so they would not slip or move , think it was three or four big washers and the whole in the washers were big enough to go over the nut then put the cup over that and wala instant lift and not going anywhere .
Old Aug 6, 2011 | 09:33 AM
ken selvy's Avatar
ken selvy
Bye the way for the rest of us , this is a cheap fix for neg camber fix for our i beam trucks , then you dont have to buy new springs and can lift the sag with one washer at a time to 0 camber , I noticed alot of owners have this problem with neg camber and wearing tires , I lowered my truck and had the i beams bent and then cut one more coil which was to low so instead of buying new springs I used washers and fixed it .
