PCM codes
Old Nov 20, 2007 | 09:26 PM
mustang_gt_350's Avatar
mustang_gt_350
PCM codes
I was wondering how many versions of the PCM there are.
Or could you post up what code our pcm is.
And is any one better than the rest?
Old Nov 21, 2007 | 01:52 AM
ernesteugene's Avatar
ernesteugene
There's more PCM codes than you can shake a stick at! My early 99 came with an XLE4, and I think Jody upgraded that to an XLE8, but I'd have to look on the sticker he put on my spare PCM that he re-flashed to be sure.
Maybe everyone will post there codes here, and we'll have a list.
Old Nov 21, 2007 | 04:33 AM
mustang_gt_350
I'm curious to how many there are. And what the changes are, mostly what internal changes have been made.
Old Nov 21, 2007 | 05:17 AM
ron's power stroke's Avatar
ron's power stroke
i have the XLE code as well..reason??? its an early 99
Old Nov 21, 2007 | 07:22 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I bet Diane has all the codes. I wish I could remember my code.
Old Nov 21, 2007 | 07:24 AM
ron's power stroke
you can find it on your DP tuner slip..
Old Nov 21, 2007 | 07:34 AM
miller_feed
Good deal Ron, I will look this afternoon and post it here.
Is life good Ron? Hope you have a good Thanksgiving.
Old Nov 21, 2007 | 07:39 AM
ron's power stroke
so far so good..thanks to you guy's.. i am still a little behind but a lot better then i was..i wish you good thanksgiving as well
Old Nov 21, 2007 | 09:00 AM
Pocket's Avatar
Pocket
There were slight changes to the PCM starting in 2002. Off the top of my head I know the tach signal input was changed and a couple of other minor differences. Other than that, most of the PCM code changes are minor tweeks in shifting, fueling, engine management, etc. My truck was originally a VDH5, and Jody now has it flashed as a VDH2. I've also had my DP-Tuner chip programmed with PMT1 shifting for the VDHx PCM's, but I wasn't a fan of the early T/C lockup while towing my quad trailer up steep forest service trails. So now everything is set for VDH2 programming and it's all gravey.
