Batteries Keep Going Dead
Old Nov 20, 2007 | 05:23 PM
Cold_Steel's Avatar
Cold_Steel
Okay batteries were dead on my truck. I recharged one of them replaced the other batterey. Then the next day both were dead again then I replaced the one I recharged on the truck. Truck started and ran fine for 100 miles. Then the Battery gage showed batteries dead again. Check the Altenator showed charging 12v I changed it any way. But still truck was very hard to start.
Now battery light is on when I turn Air conditioner on or windshield wipers. If I have nothing on seems to hold a charge slightly very slightly. If I turn somthing on well starts dropping rather quickly.
I am goin broke $$$ please help.
Old Nov 20, 2007 | 05:36 PM
ron's power stroke's Avatar
ron's power stroke
where did you get the alt. from??? check and clean all connections all the way down to the starter..also there is a plug on the top of the alt with 2 wires...there is a sharp bend on the wires and it tends to break the wire at the plug..trace all wires and make sure there not rubbing and shorting out...
Old Nov 20, 2007 | 05:52 PM
clintbonnie's Avatar
clintbonnie
If you have a good digital volt meter, measure the voltage when engine is idling.. voltage should be around 14 volts if charging properly. The battery light does show your alternator might be bad or like Ron says above, check the small wires directly coming out of the alternator.. Mine shorted out last month right about 2 inches from the plug, where they bend over the alternator housing.. I was getting an intermitted battery light on the dash..
Old Nov 20, 2007 | 07:04 PM
Cold_Steel's Avatar
Cold_Steel
Batteries keep going bad
okay i checked wires at altenator they seem fine.
the altenator I got from a O'Reilys.
Still when I drive it might be fine for 20 miles the the battery gage will show a drop. I at just confused at what it could be.
But I appreiate the help
Old Nov 21, 2007 | 01:07 AM
joshsmith7's Avatar
joshsmith7
you either A have a huge draw on the battery that we/you dont know about
your new altenator is not putting out enough
or c your batterys are shot, or at least one of them
Old Nov 21, 2007 | 05:14 AM
ron's power stroke
bring the truck back and have them test the alt...people have gotten bad alts at O'Reilys and auto zone...
Old Nov 21, 2007 | 09:43 AM
dcara's Avatar
dcara
If the batteries go dead with the truck just sitting you can do some simple tests you can do without any equipment (DMM etc.). Charge the batteries, disconnect the alternator, pull the fuse that goes to the ignition and let it sit. If batteries still go dead you know it wasn't the alternator or anything in the ignition path so your probably looking at a wiring issue. If they don't go dead, plug in the alternator, or ignition fuse (you get the idea) and repeat test.
Old Nov 21, 2007 | 11:06 AM
cangim's Avatar
cangim
If you can start the truck and then the batteries go dead after a few miles then the alternator is not charging the batteries. Tell them you want a different alternator. Check to make sure you connections are clean and good. You should be about 12.5V or so without the engine running and about 13.5 to 14.5 with the engine running. Then check the voltage again if you turn the wiper, fan and headlights on, the alt should step up the output and maintain the previous reading within a few tenths of a volt.
Old Nov 21, 2007 | 11:43 PM
ronwilll's Avatar
ronwilll
If you have two batteries and one is replaced and the other left, I understand the older battery will draw the newer one down.
I don't think it should discharge it completely though. Sounds like a dead short somewhere.
Desert-Rat
21
May 9, 2023 04:48 PM
72camperspecial
May 28, 2013 09:12 PM
a ayala
May 6, 2010 09:29 PM
vlcak
1983 - 2012 Ranger & B-Series
Nov 2, 2007 05:40 PM
willbill28
May 5, 2004 02:07 PM
