Tip on air in return lines
Old Nov 19, 2007 | 08:07 PM
kevbits's Avatar
kevbits
A local machine shop gave me a tip that he says helped a few people he knows with air leaking into the return lines. I have not tryed it yet so i dont know if it works. He said if you cap off the return line at the #1 cyl injector that goes to the filter air will not be circulated back to the IP, instead it will just go back to the tank. It also must be capped off at the filter.
Does anyone know if this is true?
Thanks
Kevin
Old Nov 19, 2007 | 08:20 PM
catfish101's Avatar
catfish101
That line keeps air from going to your IP that comes from the fuel system of the truck. You want it to be there.
Old Nov 19, 2007 | 08:50 PM
tbone91's Avatar
tbone91
There is a check valve that keeps any air in the return lines from returning to the filter. My understanding is that if the check valve is bad *and* you have an air leak in the lines, then the filter will empty out making it even more difficult to start. Someone correct me if I'm wrong.
Diesel wyatt
Feb 1, 2014 06:43 PM
Coccyx
27
Jul 6, 2013 06:57 PM
ozdatman
13
Apr 21, 2013 07:51 PM
Scout
Mar 13, 2009 01:17 PM
Schmittys diesel
Feb 16, 2007 11:52 AM
