I just looked at my 390 on my f-250(1968). The casting numbers are 02TEAA that last A, i am not sure if its a A or a 4. What i need is the port size, putting on a new weiand high rise 7282, and it says only goes on port size height= 1.93 and with= 1.34. So if anyone has a spec book can you please look it up to see what size my ports are, and if this intake will fit them. Thank you very much.
Intake port size is 1.87 x 1.34 on your D2TE-6090-AA heads. The Weiand intake should be a pretty good match. The port roof is the same height as other FE heads just the floor raised slightly compared to the 2.34 x 1.34 lowriser heads.
