odd electrical problem
Old Nov 19, 2007 | 01:06 PM
shelton's Avatar
shelton
I bought a well used 86 250 a couple of weeks ago.It has a problem with the blinkers.When you step on the brake pedal both front blinkers come on.The blinkers do not work otherwise.The hazards do not work either.Any help would be appreciated.
Greg
Old Nov 19, 2007 | 01:33 PM
PLC7.3's Avatar
PLC7.3
Check some fuses....... but I think the directional/hazard switch in the steering column may be part of the problem.
Old Nov 19, 2007 | 02:08 PM
shelton's Avatar
shelton
All fuses are good.Could there be problems with the trailer wiring.There is a mess under the truck where someone tried to wire it for trailer lights.
Old Nov 19, 2007 | 03:07 PM
tbone91's Avatar
tbone91
It sounds like the Hazard switch to me, or possibly a bad ground to the tail/brake lights. Do the 4-way flashers work? What happens when the parking lights are on and you step on the brake? What happens when you have a turn signal on and step on the brake? Any such clues could help...
Old Nov 19, 2007 | 08:12 PM
catfish101's Avatar
catfish101
Check the harness and fuse panel under your foot. Your harness may be loose and you could be mashing it when you push on the pedal. There is alot wiring under your foot on those older trucks.
Old Nov 19, 2007 | 08:58 PM
87crewdually's Avatar
87crewdually
I would start with the flasher relay first.(It's the round shiny looking thing in the fuse block usually) I'ts easy enough to change and affordable.
Old Nov 19, 2007 | 09:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
shelton,
Welcome to FTE and the IDI diesel forum.
Burnt bulbs or broken wires to either the front or rear turn signal bulbs can also cause it to act like that.
I second the do you have brake lights?
Also the flasher could be bad, it is located in the fuse panel.
The other one near the fuse panel is the 4 way flasher flasher.
Yes the mess under the trailer hitch could easily be the problem.
If it is still there, there is a connector where the rear light harness plugs into the chassis harness at the back end of the frame on the drivers side.
It may be just inside the rear cross member, but the wire should be long enough to get it outside the hole.
There is also a ground wire there that may be cut.
Famous for corrosion inside the connector if you drive in much salt/snow.
Old Nov 20, 2007 | 07:06 AM
shelton's Avatar
shelton
Thanks for the replies.I have changed the flasher and checked all fuses.The four way flashers do not work.I do have brake lights.I'm not sure what happens when you push the brake pedal and try to operate the turn signals.
lemasters f100
Feb 15, 2013 12:16 AM
wyckedcombo17
Jul 25, 2011 01:23 PM
Kyle 4X4 4life
May 22, 2011 12:39 PM
vonvon
May 5, 2011 12:57 PM
Daisy Cutter
Electrical Systems/Wiring
Oct 2, 2006 01:37 PM
