1979 F250 Blinker switch problems
Old May 5, 2011 | 01:37 AM
vonvon's Avatar
vonvon
Why dont my blinkers flash when I turn the switch on, Ive replaced both the flashers and the switch and still cant get them to work. Any body have any ideas on what I need to do?
Old May 5, 2011 | 09:33 AM
stuart1's Avatar
stuart1
Bulbs, fuses, wires.
Old May 5, 2011 | 11:57 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 73-79 F-series forum.
First, WELCOME to FTE!
Second, having gone through similar issues with my '74 Highboy, I have a question.
Do your brake lights work?
Old May 5, 2011 | 12:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
There are two flashers behind the dash, one for the turn signals, another for the 4-way emergency flashers.
These are basically the same two prong flashers, but the 4-way has a louder click because it's a heavy duty flasher.
Where was the flasher located you replaced?
Old May 5, 2011 | 12:43 PM
Justin's Green Truck's Avatar
"Ive replaced both the flashers"
Get a wiring diagram specific for your truck or autozone online has it too for free. Use that and a multimeter to check it. I had problems with mine too and used this to find that the switch in the column was bad.
Do neither side front or back work?
Do the blinker indicators in the instrument cluster work?
As said before, check fuses, wiring. Also check ground points.
With mine, i replaced the switch only to have it go out on me a year later. some of them, maybe all of them, are made cheap so dont rule out the switch just because it's new
Old May 5, 2011 | 12:57 PM
NumberDummy
The way the sentence reads: "I've replaced both the flashers and the switch" could be taken as "I've replaced both the flasher and the switch."
I typed the info for clarification, since some peeps are unaware that there are two flashers.
will32_
24
Sep 28, 2014 10:18 PM
lemasters f100
Feb 15, 2013 12:16 AM
heatherc
Dec 19, 2012 08:59 PM
wyckedcombo17
Jul 25, 2011 01:23 PM
Lincoln White
Dec 10, 2009 09:08 AM
