I had the same prob (no tach). I have the same setup except 3.55 gears. I shift out of first around 10mph or so.
Also, if you want an easy tach install do what I did.
Buy an instrument cluster from the same year truck (or close) and it is a simple 30 minute bolt in swap.
Look here for a cluster: [a href=www.car-part.com]www.car-part.com[/a]
