transmission issues in my new 92
OK, so my "new to me" 92 has some issues. I guess I should start with the transmission.
I'm not too up on the computer controlled trucks, but I can do good research if I'm pointed in the right directions. Bear with me, and I'll get it.
I pulled my VIN, and it says I have a "4 SPD AUTO TR-NAAO E4OD(4R100)". It shifts hard into each gear. VERY hard. It seems to shift on time, and downshifts when you would expect it to, but I've never felt a transmission that shifted this hard. It'll clack your teeth together if you're holding your mouth wrong...
Fluid level looks good. No leaks to speak of. PO said that a few things started acting funny after he power-washed the block down last week. I don't know if one has anything to do with the other, but the engine started idling very low at about the same time, he says. Other than a low idle (and I'll have to verify that with my own tach), the engine seems to run fine, if maybe just a little on the warm side.
Any ideas on the trans shifting issue?
<div_prefs id="div_prefs"></div_prefs>
Well, you should do a fluid flush on that tranny, and replace the gaskets and the filter. Adding a tranny cooler should help also. I think the computer can diagnose some issues on the tranny (pulling codes), but i'm not very sure. I read that you bought that truck at a very nice price, i hope it doesn't give you much trouble . And welcome to this side of the forum!.
It's already got a trans cooler. According to the service records I have, it had a fluid replacement and filter service last year.
I'll have to see about getting my local mechanic to pull codes for me Monday. I don't have a code reader, and as of right now, I don't know how to use one. I'll change that limitation ASAP. I really don't like paying someone to do for me what I should be able to do for myself.... My '85 is carbed and has a C6, so I didn't need this ability 'till now.
Sorry for the out-of-focus pic. I couldn't get the camera to focus on the foreground item. It wanted to focus instead on the background.
The computer needs the overdrive cancel switch to work and so do you if you want the truck to shift properly. The switch should really be cycled on and off during the diagnostics tests otherwise you will ALWAYS get Codes 65, 97, or 629 when you run the diagnostics tests. Not to mention the fact that you have no way to control whether the transmission ever uses the overdrive gear.
The stalk is replaceable. Heck I think the switch assembly at the end of it is a separate item. Check the Forum Sponsor website or NPD, LMC. Once you have it fixed, clear fault codes from the computer by disconnecting the battery for 5-10 minutes. Reconnect and go for about a thirty minute drive.
I had a hard time getting the headlight **** off because the spring tab was all deformed when the po tried to pry off the **** or something. I knew how to use a little screwdriver to release the tab, but it wasn't working right because the tab was all bent up.
At least now I can test the 4x4 switch.
flyingtexan
01-25-2018 07:51 PM
HooniverseJeff
25
10-07-2016 02:06 PM
Scott1965FordF100
08-20-2014 04:15 PM
