3.0 chugging
Old 11-18-2007, 09:04 PM
78fordman's Avatar
78fordman
78fordman is offline
3.0 chugging
i have a 97 3.0 flex fuel in a taurus, the ses light is on, but i do not have a code reader easily available. it chugs just off idle. milage is great and is fine off idle. i checked for vacume leaks but did not find any. any ideas?
Old 11-18-2007, 09:06 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Pull the codes is the first step.
When was the last tune up?
Old 11-23-2007, 08:03 AM
tomw's Avatar
tomw
tomw is offline
Pull the codes. Pep Boys is charging for that now, but will 'credit' the fee towards repair cost. A low-budget reader is in the $39.95 ballpark.
You could also check that the MAF is not coated with gunk. If you have a 'free flow' air cleaner, you may have over-oiled it and coated the MAF heated wire sensor with stuff. Clean GINGERLY. What is happening is that it does not sense the air flow quickly because it is insulated by dirt.... Your mileage may vary.
tom
Old 01-23-2008, 07:26 PM
jrwrocks's Avatar
jrwrocks
jrwrocks is offline
i work for autozone we read them for free
Old 03-02-2008, 08:37 PM
78fordman's Avatar
78fordman
thanx guys turned out to be the cam position sensor.
Mater08
1999 to 2016 Super Duty
07-16-2016 09:10 PM
BrendanFitz
01-01-2016 11:32 PM
danocross
10-29-2008 10:40 PM
Pitchfork87
05-11-2008 06:46 PM
DAN-D-DIESEL97
29
04-22-2007 07:28 PM
Quick Reply: 3.0 chugging
