Sponsored by: Real Truck
Spark Plugs
Old Nov 18, 2007 | 08:33 PM
jmoore1045's Avatar
jmoore1045
Spark Plugs
03 f350 with 114500 miles on it. Started to miss a little on my way home tonight.
Question is what type spark plugs to use. Do i go with the factory plugs or does anyone prefer another brand?
thank You
Old Nov 18, 2007 | 08:38 PM
khadma's Avatar
khadma
Carpenter Local 745
Ford truck = Motorcraft/Autolite plugs.
Old Nov 18, 2007 | 09:49 PM
tom pw's Avatar
tom pw
Bet you got a COP going bad.
Old Nov 18, 2007 | 10:09 PM
heidiandmax's Avatar
heidiandmax
Ford/Motorcraft
Old Nov 18, 2007 | 11:01 PM
biz4two's Avatar
biz4two
Arrow
What khadma said...
Just a friendly tip: But since you are going to change the plugs...change the COP boots while you are at it.
biz
Old Nov 19, 2007 | 08:02 AM
Jim59's Avatar
Jim59
You say it is just missing "a little." As in ... when you give it a little gas? If so, that is a "light load miss," and very well may be one of the COP's (coils). It is not rare.
Also, I don't know when Ford changed the cyl heads (others here will know), but are you aware of the spitting spark plugs? Use great care when installing the new plugs ---- torque wrench and most people seem to stay with Motorcraft plugs.
Also, blow out the spark plug well before you remove the plug, I've had debris/water down in there that could fall into the cylinder.
Also, liberal amount of dielectic grease at the COP boot-spark plug contact areas.
Good luck.
Old Nov 19, 2007 | 08:27 PM
jmoore1045's Avatar
jmoore1045
A little miss turned into a very noticable miss tonight.
Will replace plugs with motorcraft and cop boots before I start replacing cop's
Thank you all for the info.
Rifle
Electrical Systems/Wiring
Jan 22, 2012 07:32 AM
someday
General Automotive Discussion
Sep 19, 2010 09:09 PM
traildawg
Jun 25, 2002 09:22 AM
Jul 11, 2001 04:55 AM
millbobs
Mar 30, 2001 06:26 PM
