Sponsored by: Auxito
JBA Headers-#16776
Old Nov 18, 2007 | 05:29 PM
duggyb's Avatar
duggyb
JBA Headers-#16776
http://store.summitracing.com/partde...5&autoview=sku
i am wondering how well these headers will fit my 1997 F150 with a 4.6L and 5 speed.
on the summitracing site they all say they wont fit if i have a manual transmission....yet i am wondering how thise is goin to affect anything?...is the bellhousing bigger on a manual or what would cause it to be different.
reason being i came across a really good deal on used set of these and would like to replace my stock leaky manifolds.
so will they fit my 5 speed?
THNX
Duggy
Old Nov 18, 2007 | 05:56 PM
Matts72's Avatar
Matts72
Never put on used headers... you'll never seal them.
Old Nov 18, 2007 | 06:22 PM
duggyb's Avatar
duggyb
even with a good set of copper seals?
i have never heard of this before.
THNX
Duggy
Old Nov 19, 2007 | 02:37 AM
LxMan1's Avatar
LxMan1
Why were they removed from the previous owners truck? JBA usually makes a good header. If they were OK on the old truck, they should seal with good gaskets on yours.
Old Nov 19, 2007 | 07:00 AM
duggyb's Avatar
duggyb
i am not sure why they were removed...but this guy bought them and the seller told him they were for a 5.4L truck.....but they are actually for a 4.6L truck....so now he is just trying to get rid of them...
they appear to be in good shape...and supposedly only have 300 miles on them.
also do you know anything about the manual transmission thing?...is it going to affect the headers or no?....right now my down pipes after the header are all custom around the transmission and i have dual pipes with 2 Flo-Pro mufflers out the passenger side.
i really don't see how it could affect things since the headers don't go back as far as the transmission.
THNX
Duggy
Old Nov 19, 2007 | 09:47 AM
Pubale's Avatar
Pubale
I noticed on the summit racing site that the header application says 'yes' to a floor shift manual trans. and 'no' to a column shift manual trans.Which one do you have?. I would suspect that the column shift linkage would interfere with the headers.
Old Nov 19, 2007 | 11:53 AM
duggyb's Avatar
duggyb
here is what my shifting setup looks like
Manual...Floor Shift
Transfer Case...Floor Shift
i just pulled this image from a truck on ebay becuase i am at work right now.
http://i9.ebayimg.com/08/i/000/c4/f0/d11b_3.JPG
THNX
Duggy
Old Nov 19, 2007 | 12:13 PM
Matts72's Avatar
Matts72
These are designed to bolt right up to the factory Y pipe, so they will fit, the fitment guide says that they won't fit standard column shift, but that is because it was never an option on these trucks.
Old Nov 19, 2007 | 02:44 PM
duggyb's Avatar
duggyb
alright....so they will fit?....good.
now if i buy a very good Copper or Aluminum gasket and some good stainless studs it should seal up right??
the copper gasket i was looking at was about $45 on summit...dont have link right now.
or can anyone make recomendations on gaskets/studs?
THNX
Duggy
dualwheels66
Modular V10 (6.8l)
Jul 20, 2012 06:26 PM
FX4 5.4
Sep 26, 2009 08:03 PM
NJbronco138
1978 - 1996 Big Bronco
22
Mar 8, 2004 10:04 PM
