Sponsored by: Real Truck
2003 F250 locking hub question
Old Nov 18, 2007 | 04:57 PM
dbranco's Avatar
dbranco
Just bought the truck and can someone send me a pic of the stock locking hubs that should be on the truck.. I just filled up for the second time in 200 miles. Just figured out that my MPG is 9.333 which does not sound right...
So I engaged the 4x4 hi in the cab and the wheels were locked.
Got outside and tried to unlock them and went back in drove back for about 10 feet. Engaged the 4x4 again from the cab and they worked again????
I am assuming the guy that I bought the truck from changed them to something else. I tried looking for the Free and lock on the hubs and it is not there plus one hub is cracked the plastic on the **** to turn.
I need help here because it still is under warranty and what to make sure the guy does not pull anything funny. So I am trying to educate myself here.
And help would be appreicated...
Thanks
Dan
Old Nov 18, 2007 | 05:02 PM
Benny2002's Avatar
Benny2002
Righty tighty lefty loosey, the front driveshaft will always turn when in 4x4 but the hubs can be engaged or disengaged during this process.
Old Nov 18, 2007 | 05:17 PM
dbranco's Avatar
dbranco
After reading a little more it is a 03 F250 Super duty... Are they suposed to have auto locks? I have a switch on the dash for the 4X4???
If they are auto hubs why can you turn the **** on the hubs??
Even after I turn the hubs in both directions the 4X4 still works?
Old Nov 18, 2007 | 05:37 PM
Benny2002's Avatar
Benny2002
The 4x4 will always work with the switch but the wheels wont always be engaged. The manual option is if your a super stuck, the auto takes a few feet and a few seconds to engage
Old Nov 18, 2007 | 05:43 PM
dbranco's Avatar
dbranco
Should I turn the **** to the left or right to auto? If I am looking at the hubs?
Can these be changed out to manual hubs? And if yes what is the process is it as easy as buying manual locks and install? Price?
Also there is a noise when I engage 4 low... Just while it is engaging after that no niose. is that normal.. It sounds like something is actuating?
Should you be able to hear the hubs unlock when driving backwards?
How I ensure that the hubs are unlocked out of 4X4?
Thanks for all of the help so far..
Dan
Old Nov 18, 2007 | 06:01 PM
Rongold's Avatar
Rongold
Auto Hubs
All trucks with ESOF came with "auto-hubs" from the factory. Clockwise is "lock", and counter clockwise is "auto". The writing on the hubs is probably worn off. Turn your ESOF switch to "2wd" and drive the truck for at least a 1/2 mile. Then, go home and get under the front of the truck. Grab the U-joint behind each front wheel and try and turn them--if you can turn each one, they are OK--If you cannot turn one, that one might be bad, or hasn't released yet. Sometimes it takes some time for them to release, but 1/2 mile should be enough. The late (99 & up) hubs are not like the older ones--you cannot hear them click when they disengage.
RON
Old Nov 18, 2007 | 06:11 PM
playsinmud's Avatar
playsinmud
You can change them out very easy. 'bout 100-150 buck for a set of Warn Hubs.
Take the big snap ring out off, and it's all down hill. Takes about 1/2 hour for the whole job.
Old Nov 18, 2007 | 06:21 PM
dbranco's Avatar
dbranco
If I change over to manual hubs will it help with my MPG????
Right now I am at 9.333 driving like grama?
Old Nov 18, 2007 | 06:49 PM
dbranco's Avatar
dbranco
Just went down the road and the axle on the drivers side was stilllocked and the passanger was freed.... So I am assuming I am having a problem with the hubs?
If I wanted to replace the stocks auto hubs with a aftermarket are there any out there?
Old Nov 18, 2007 | 06:55 PM
aldridgec's Avatar
aldridgec
There is so much out there about these hubs and their problems it is ridiulous. Do a quick search and you'll get a ton of info.
Old Nov 18, 2007 | 06:56 PM
dbranco's Avatar
dbranco
What should I do a search for?
What keywords?
Old Nov 18, 2007 | 07:01 PM
aldridgec's Avatar
aldridgec
Why don't we try:
auto hub
manual hub conversion
4x4
esof (electronic shift on the fly)
c'mon dude. Do I have to hold your hand?
Old Nov 19, 2007 | 05:48 AM
playsinmud's Avatar
playsinmud
dude call NAPA give them year, make, model. and then tell them you want the Warn lock outs. 100-150 bucks depending on your discount.
Old Jan 14, 2008 | 11:41 AM
robin1t2002's Avatar
robin1t2002
When in the lock position do you still need to engage using the dash switch? If so what is the point?
RON
Old Jan 14, 2008 | 11:45 AM
robin1t2002
Did that and didnt find any info.
