Dc Called Me
Old Nov 17, 2007 | 10:24 PM
2 stroke man's Avatar
2 stroke man
Dc Called Me
yup, i got a call from Washington DC yesterday. i had called my congressman, hal rogers last week complaining about fuel, and how people with farm tags should be legal to run farm diesel. we ran a test tank although illegal to tes mileage. 5 MPG MORE!!!! empty, on the road runnin 70+mph. WOW what a diff, and i can buy it in bulk for a buck less per gallon than Road diesel. well the person in washington sempathized with us, and they are gonna talk to George B about decairing farm diesel legal to help farmers keep their heads above water in the wake of the hay crisis. we may get blessed. that is all it will be, a Blessing from God. amen.
Old Nov 17, 2007 | 10:28 PM
1997F-350's Avatar
1997F-350
hey i am a farmer too....sign me up . when we had the hurricanes that is all they were selling but still taxing it though.
Old Nov 17, 2007 | 11:32 PM
kawa's Avatar
kawa
What's the differance in farm diesel and road diesel other than color?
(And price, and minus mucho taxes, etc)
Why would your mileage increase?
Old Nov 18, 2007 | 07:13 AM
WALJON's Avatar
WALJON
From what I seen at the bulk plants,they are the same fuel just with dye. It would be nice to run it,It is so much cheeper,I don,t know how it is for you guys down there but up here in Canada they have fuel cops ,these guys drive around pulling trucks over and check your fuel and if you are running colour they will fine you all the way back to your last reciept of dino,and it is a big fine as it is
Old Nov 18, 2007 | 08:48 AM
arkredneck's Avatar
arkredneck
how much offroad diesel could you mix with highway diesel before the color would change?
Old Nov 18, 2007 | 09:17 AM
tjbeggs's Avatar
tjbeggs
Very little! same with tranny fluid in the fuel. wouldn't take much to make the officer think your running off road fuel.
Old Nov 18, 2007 | 09:19 AM
ltfox's Avatar
ltfox
Its all the same. Only difference is the dye. The day of having a higher sulfer diesel fuel is long gone.
Old Nov 18, 2007 | 09:42 AM
MADVAN's Avatar
MADVAN
Not true. Has to do with were it comes from.
In the north east off road/heating oil can still be 5000ppm or more.
Same goes for Kero.
Its more than just the red dye in some locations.
Note---If you run off road fuel. You have to run the correct motor oil to combat sulfuric acids. The newer CJ does not have it in the package anymore do to it causes carbon behind piston rings.
Tidbit-
Although ultra-low sulfur diesel fuels reduce the production of sulfuric acid, nitric acid production increases as nitrogen reacts with water vapor and heat. However, CJ-4s also have higher oxidative stability, meaning that nitric acid formation from the oxidation/nitration process should develop at a slower rate
Bill
Old Nov 18, 2007 | 10:37 AM
WALJON's Avatar
WALJON
I wonder why it is dif. in the north east?
Old Nov 18, 2007 | 10:51 AM
jboard's Avatar
jboard
I always thought It had more sulfur in it than on road fuel.
--------------------Jeremy
Old Nov 18, 2007 | 12:57 PM
2 stroke man
it is higher sulfer, thus better lubrication because the sulfer is a carrying agent for a lubricant. thats what the local injection shop says. they say it only helps ur engine. that is, if its fresh. alot of it sets in tanks on the farm so long it gets bad. but, i know where to get it fresh. EVERYONE NEEDS TO CALL THEIR REPRESENTATIVE AND PITCH A FIT
Old Nov 18, 2007 | 04:33 PM
kawa's Avatar
kawa
Just call me stupid....what's CJ?
Roger
Old Nov 18, 2007 | 05:00 PM
tjbeggs's Avatar
tjbeggs
Diesel engine oil rating. Its the newest oil designed for the ULSD in mind
Old Nov 18, 2007 | 05:06 PM
FARM69's Avatar
FARM69
Heck I can't remember the last time I haven't ran a tank of on road fuel. Last time I checked Ruby's sulfur sticker said "may contain sulfur amounts higher than 500ppm." But I know that a lot of suppliers have already switched to ULSD.
The problem about the dye is that it keeps dilluting. So even after 3-4 tanks of on road fuel than can still tell that you have used Ruby in the past. They always have these demonstrations at farm shows.
The day of LSD is going to be over. I know most suppliers in my area have already switched and blending with soy to combat the lubrication problems with ULSD.
I've never heard about the sufluric acid.
Old Nov 18, 2007 | 05:48 PM
fuelman's Avatar
fuelman
Things can be different in the NE because they still use heavy quanities of heating oil to heat in the winter. The old 1000ppm known as high sulfer in the 90's has a higer btu rating which is why it can improve mpg.I know in the midwest(Ind,Il,Wis.Mo,etc) the only thing available is ulsd 15ppm,unless you go to a refinery that has a terminal(loading trucks) in it.Many pipelines won't transport LS500ppm for fear of contamination to ulsd.
