Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Hey Morris!
Old Nov 17, 2007 | 09:30 PM
51dueller's Avatar
51dueller
Hey Morris!
Since Chris and Ryan are stepping up their Flathead engines with dual carbs. I figured you better one up them on the '56 M-100. Hows this?
Oh Sherm they do make a 302 to 351W intake adapter so you could run it on the 1983!
Old Nov 17, 2007 | 09:53 PM
Snowking's Avatar
Snowking
Don't mean to butt in, but I am planning on a 4 barrell 390cfm Holley. (just to clarrify)
That would be cool but at least on Flatheads better performance and reliablity (mainly reliability) are found with a single 4 barrell. But mmultiple carbs looks 10x at least cooler and classical. go for it!
Old Nov 17, 2007 | 10:20 PM
effie_man's Avatar
effie_man
i dont think i need to say anything except...................... "Hey you guys!!!!!!!!!!!!!!!!"
Old Nov 17, 2007 | 11:52 PM
Fomoko1's Avatar
Fomoko1
Now I`m planning on the 56 M100 being mostly stock with the Y-Block.
The 53 M100 gets the frame clip and the 302/351/?.
Old Nov 18, 2007 | 02:56 AM
Snowking's Avatar
Snowking
Thats does make ALOT more sense then having the 53 with the Yblock and 56 with 302, atleast now one is stock.
Old Nov 18, 2007 | 06:53 AM
96sherm's Avatar
96sherm
i couldn't imagine keeping fuel in a 351 if it had 3 carbs... thanks but i'll stick with the edelbrock air gap i have.
Old Nov 18, 2007 | 10:19 AM
51dueller's Avatar
51dueller
Sherm you have to remember that most small 2V carbs are around 200 cfm to 250 cfm. So you could still have 600-750 cfm on your 351W.
Old Nov 18, 2007 | 11:28 AM
preppypyro's Avatar
preppypyro
Very cool indeed. What was the price on that intake Nathan?
I also wonder how hard it would be to set up the three two barrels...
Old Nov 18, 2007 | 11:29 AM
Snowking's Avatar
Snowking
But there are also 2 barrell carbs up to 500 cfm
Put 3 of those bad boys on be using a garden hose for a fuel line.
Old Nov 18, 2007 | 11:37 AM
51dueller's Avatar
51dueller
Ya but those 500 cfm ones are gas pigs. The venturies get so big you loose port velocity and efficiency.
As far as setting up the 3 carbs, it depends on your throttle linkage. The easiest would be to run the engine on a dyno and monitor the A/F mixture. You would most likely have to change settings many times till it was dialed in.
Old Nov 18, 2007 | 11:44 AM
Snowking's Avatar
Snowking
But from red light to red light sure is a impressive ride.
Old Nov 18, 2007 | 12:20 PM
96sherm's Avatar
96sherm
wouldn't it be quite a pain in the *** for the ordinary joe to get them all running right?? how would they work?? all pumping at once, or cutting in at certain throttle pressures??
Old Nov 18, 2007 | 12:47 PM
Fomoko1's Avatar
Fomoko1
My thoughs too.
I need to find decent rocker arm assemblies, mine aren`t good. Other wise the 56 may have go FE.
ryans88gt
Apr 5, 2014 10:36 PM
SteveBricks
Colorado Chapter
Feb 11, 2011 09:18 PM
GwarForAll1021
2004 - 2008 F150
18
Apr 27, 2009 03:49 PM
HappyJack
Kansas Chapter
42
Mar 11, 2007 12:53 PM
