Ok sorry not to day with the video long long night and no day light left so see. Il see what I can do with it tomarow. Ya I got a winsheild washertank with pump for $10 at a junk yard and found some lil metal tube that the rubber hoseoff the pump could slide over and then drilled a lil hole in the pipe that I replaced the cat with and put the tube through and mounted the tank on the side of the frame from factory holes. Ran wires in to the cab on a switch and it works. But driving hm today and playing with it I think im putting way to much oil in the pipe. I got hm and there is oil and smoke all over my tailgate and bumber and the side of the bed. So defenitly need to find away to burn it better!!! My tailpipie smells like straight oil and drips oil out of bc me flippin the switch to much!! But it is a way cheap way to make cars behind you disapear!!!!!
you could inject the oil in the downpipe where the EGT's are a lot hotter than where the cat is. i know it's closer to the turbo, but it shouldn't hurt the turbo. use some really light weight oil or use your old oil when you change your oil. or you could just go to www.diy-injectors.com and buy a set of stage 1's and get the real thing. sorry but black smoke to me is useless if your not haulin' *** when your blowin' it.
on edit: i forgot to say, i would also love to see some videos of this!!! this is hilarious!!!!!!
I would like to hypothetically state that in the event of everything going up in smoke, I got first dibbs on the tailgate. LOL Just kidding, but be safe man get a WORKING fire extinguisher on board soon. My trailer ignited 6 days ago while I was welding a spare tire bracket. Just a little hydraulic oil and whoof !!!! No damage though as I anticipated it and had the hoes nearby, lol.
Ya injectors are def on my list but no funds right now and still trying to get supporting mods for them. I think im guna skip the stage I's and II's and go to III hybirds. Im working on getting there tho. It moves pretty good for I got but 3.55s dont turn 37" tires very good so that slows me down. But everywhere I go now Im blowing 3 times as much smoke.....it seems to be getting whiter and whiter now. I think I might put some black die in the washer tank and see what happins. lol!!
tip: get rods and head studs if you get stage III hybrids
check my vids for how quick my truck is with the stock turbo and trans still!!! stage IIs sure are fun
i just said the hell with it and used kerosene, i even went all out one year for the cubscouts and launched a model rocket down a line into the fire to light it off.
as for the tailpipe mod i would hook up an ignition coil and a spark plug and be done with it
