No start????
Old Nov 17, 2007 | 12:14 PM
jrichardson42's Avatar
jrichardson42
No start????
I have a 96 ford E-350 with a 7.3 powerstroke diesel and it started running real rough then it died i pulled the codes and it had a bad cam sensor and i replaced it and it still wont start and now its giving me a p0603 code witch is a ctrl mod kam error would this keep the van from running.
Old Nov 17, 2007 | 01:15 PM
Action4478's Avatar
Action4478
603 Won't keep it from running & the cam code could have been set by long crank...
Check your fuses, oil , batteries...Are you getting a WTS light ?
Any smoke?....
Old Nov 17, 2007 | 04:57 PM
Neal 97 250's Avatar
Neal 97 250
Make sure the connection is good at the cps and that it is installed all the way in.
Old Nov 19, 2007 | 04:39 AM
jrichardson42
the cps is in all the way and im not getting any smoke and when i try to start it it tries to start i checked all the fuses i checked the level in the hpop and it was full i was going to check fuel pressure but how do check the fuel pressure on a powerstroke and what should the fuel pressure be.
Old Nov 19, 2007 | 05:54 AM
Cuda_jim's Avatar
Cuda_jim
The FP test port is located on the driver side of the fuel filter housing. It's a schrader valve (tire air valve). You can use a tire pressure gage but it gets messy and takes 2 people, one cranking the engine the other holding the gage. You should see at least 30psi while cranking.
Old Nov 19, 2007 | 07:06 AM
jrichardson42
i have a nother question on further checking with a scan tool the engine oil temp is reading almost 300 deg and it sat all weekend not pluged in would this have anything to do with the no start
Old Nov 19, 2007 | 07:09 AM
bkcowboss's Avatar
bkcowboss
Yes it can have something to do with it, as the oil temp sensor sends a signal to tell the GP's how long to stay on.
edit the pcm uses the oil temp signal to determine glow plug actuation length
Old Nov 19, 2007 | 08:39 AM
jrichardson42
This may be a stupid question but were is the oil temp sensor on a E-350 van i have a book and its not were the book says it is and can the ecm be bad getting a bad signal from the ots im at a loss right now.
Old Nov 19, 2007 | 09:07 AM
Action4478's Avatar
Action4478
It should be ...Here....
Thank TJ for the Pic...
Old Nov 19, 2007 | 09:37 AM
MADVAN's Avatar
MADVAN
X2
With the out of range EOT. The GPR will not drop.
Unplug the heater and check fuses, and links at the gpr.
Bill
Old Dec 1, 2007 | 05:17 AM
jrichardson42
I finally got to work on this thing i checked the fuel pressure and it was 0 on further inspection there was fuel pump has been leaking im replacing the fuel pump and i need to replace the rubber seals on the fuel return lines between the the lines and the fittings on the back of the heads and i ordered them from ford and they are way to big and they checked from 94 to 99 and they all call for the same seal so is there any place else i can find them.
jrichardson42
Old Dec 3, 2007 | 04:36 AM
jrichardson42
I found the seals after i talked to another ford dealer they list 3 different seals so i got the right ones thanks for all the info this really helps.
bkvanbek
Oct 16, 2014 08:31 PM
5.4Triton
1997 - 2003 F150
15
Mar 30, 2012 07:36 PM
mike bell
Nov 8, 2010 03:41 PM
motorcycleemporium
Sep 2, 2010 07:31 PM
