96 460 code 172 ????
Old Nov 8, 2010 | 12:30 PM
mike bell's Avatar
mike bell
40 k on this moter runs like heck catches after 2 or 3 minutes on hiway then runs better parts store guy says code means running lean.....what do i start with here.....mike in omaha
Old Nov 8, 2010 | 03:41 PM
rla2005's Avatar
rla2005
DTC 172 can be caused by any leaks in the exhaust system upstream of the O2 sensor. It can also be an indication you have a vacuum leak in the intake system as well. Low fuel pressure from a bad pump, faulty fuel pressure regulator or clogged filter can also cause a lean code. Once those potential causes have been eliminated it may be time to suspect a worn out or contaminated O2 sensor.
mpu
Testing.....
Mar 5, 2015 10:03 PM
mike bell
Jun 8, 2014 11:27 AM
TOPPENTECH
Apr 1, 2014 10:10 PM
run6.0run
Feb 18, 2014 10:40 PM
mike83f250
Nov 6, 2011 08:52 AM
