rubbing alcohol will help pass E-check?
Old Jan 13, 2006 | 09:16 AM
Silver Streak's Avatar
Silver Streak
I don't know about the e check, but rubbing alcohol will help reduce the effects of condensation in your fuel tank. Water and gas don't mix, but alcohol mixes with both so it will dry up a wet tank.
Old Jan 13, 2006 | 09:57 AM
quicklook2's Avatar
quicklook2
ohio's e-check is nothing to worry about.
do a basic tuneup and drive to get cats hot and it should pass.
now in california you may have trouble but not in ohio.
also, e-check is free in ohio now thanks to cigarette smokers.
Old Jan 13, 2006 | 01:24 PM
Hooker Bob's Avatar
Hooker Bob
One of my techs use to run a E-station in Calif. He said that it would work in some cases. He said on some vehicles that should have passed but didn't, they would start them up and add methanol and take them out on the freeway blow them out good then bring them back in then they would pass. He said the alcohol would help knock the deposits out of the combustion chambers and change the fuel chemistry enough to lower the emmisions to get a passing readout.
Pat
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
