90' F150 inline 300
Old Jan 12, 2006 | 04:41 PM
pintopower8's Avatar
pintopower8
90' F150 inline 300
my work truck has been having problems starting. it turns over fine, but doesn't seem to get fuel right away. It takes a good bit of cranking to actually get it going. They tell me they can't remember the last time the fuel filter was changed. Sound look a solution? any other ideas?
Old Jan 12, 2006 | 06:06 PM
jb1390's Avatar
jb1390
does it have efi? If so, can you hear the pump turn on when you turn the ignition on? Fuel filter would be a good place to start. Does it have dual tanks, and if so, does it have the same problem with both?
Old Jan 12, 2006 | 06:59 PM
pintopower8
It is EFI. You can hear the fuel pump running. it has dual tanks but the second one has a hole in it so we only use one.
Old Jan 12, 2006 | 10:18 PM
jb1390's Avatar
jb1390
change the filter. I think it might be possible that the pump isn't putting out enough pressure, even if it's running. If the fuel filter doesn't work, you will have to test the output pressure/flow of the pump. There are instructions on how to do that here on the site somewhere, but the filter is a cheap and easy thing to do, so do that first and see what results you get.
Old Jan 12, 2006 | 11:16 PM
300 4 ever's Avatar
300 4 ever
Mine would do the same thing till I replaced the fuel pressure regulator on the fuel injector rail. Its between the one and two intake runner if I remember correctly. Do the fuel filter first, that can be the culprit.
Old Jan 12, 2006 | 11:52 PM
stractor's Avatar
stractor
Do you have two tanks on the truck and does the fuel from one fill up (Transfer to) the other. If you do you might have the bad fuel pump check valve problem. This also lets the pressure in the fuel lines bleed down very rapidly when the engine is shut off. Upon restart the engine will crank for a long time due to the lack of pressure in the fuel system. I would have to try and start a second time and it would start. There was a recall on this but it has expired now. The fix is to replace the pressure regulator and install inline check valves at the tank/tanks or replace the offending pump/s.
stractor
Old Jan 13, 2006 | 02:55 PM
pintopower8
strator it sounds like you had the same problem as me . It usually will start the second time.
NashvegasMatt
17
Dec 12, 2016 12:12 PM
Tartersauce53
Dec 9, 2016 04:49 PM
RickBraden
6.7L Power Stroke Diesel
34
Dec 26, 2015 11:14 AM
altruego
May 17, 2011 04:04 PM
low-blow00
Nov 4, 2009 07:57 AM
