compression check, what 2 look 4
Old Apr 24, 2002 | 08:12 PM
tealboy1's Avatar
tealboy1
i am going 2 check compression saturday. pls offer suggestions on how 2 perform and what 2 look 4. how much compression should i get?
thx for all the help,
dave
Old Apr 24, 2002 | 10:04 PM
nitro94's Avatar
nitro94
Best results are with a warm engine. Disable ign. system, open throttle fully. Highest and lowest readings should be within 80% of each other.
Old Apr 25, 2002 | 06:07 AM
inliner's Avatar
inliner
Do you still need to disable the ignition if you use a remote starter switch and the ignition switch turned off?
Old Apr 25, 2002 | 10:52 PM
nitro94's Avatar
nitro94
no.
Old Apr 27, 2002 | 03:18 PM
tealboy1's Avatar
tealboy1
[updated:LAST EDITED ON 27-Apr-02 AT 04:36 PM (EST)]why disable ignition? I performed the test today by taking all plugs out (to minimize battery strain and eliminate compression in other cylinders) and let the plug wires hang down. Seemed to work but maybe i did it wrong.
By the way, my results on the 300 six were from front of engine to rear toward cab:
147, 150, 160, 149, 155, 156
Old Apr 28, 2002 | 03:49 AM
inliner's Avatar
inliner
With some electronic ignitions you can damage them if you don't allow for all that energy to go some where. I think you can do it that way if you ground all the plug wires.:-staun
Old Apr 28, 2002 | 03:18 PM
STR8 SIX's Avatar
STR8 SIX
Theunknown
1997 - 2003 F150
May 13, 2011 09:16 PM
RobW
1983 - 2012 Ranger & B-Series
Oct 23, 2009 09:17 PM
showbizfcb
Jun 5, 2007 05:53 PM
MontanaFord
13
Jun 27, 2004 01:18 PM
I_Thnk_Ford
Mar 8, 2004 12:57 PM
